01-13-2014, 14:23 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Ottoman Empire State (Turkey)
Member: 598417 Status: Offline Thanks Meter: 57 | SHV E160S After İmei Patch Lost Network ScreenShot Logs: Code: INFO : 13.01.2014 11:57:02 > Set up system language English (file: English.ini) INFO : 13.01.2014 11:57:02 > Welcome to Octoplus/Octopus Box Samsung software version 1.4.4 INFO : 13.01.2014 11:57:02 > ----------------------------------------------------------------------------------- INFO : 13.01.2014 11:57:02 > To connect SHV-E160S phone you have to perform the following steps: INFO : 13.01.2014 11:57:02 > 1. Go to dial window. INFO : 13.01.2014 11:57:02 > 2. Enter "319712358" number. INFO : 13.01.2014 11:57:02 > 3. Enter "996412" password. INFO : 13.01.2014 11:57:02 > 4. Go to System->SIO mode. INFO : 13.01.2014 11:57:02 > 5. Select "Modem" radio button for USB section. INFO : 13.01.2014 11:57:02 > 6. Go to dial window. INFO : 13.01.2014 11:57:02 > 7. Enter "*#9090#" number. INFO : 13.01.2014 11:57:02 > 8. Set "Diag config" to "USB" value. INFO : 13.01.2014 11:57:02 > 9. Restart phone. INFO : 13.01.2014 11:57:02 > 10. Press "Read Info" in software. INFO : 13.01.2014 11:57:29 > ----------------------------------------------------------------------------------- INFO : 13.01.2014 11:57:29 > Platform: Samsung Anycall INFO : 13.01.2014 11:57:29 > Selected port: COM39 INFO : 13.01.2014 11:57:29 > Selected model: SHV-E160S INFO : 13.01.2014 11:57:30 > Detected phone model: SHV-E160S INFO : 13.01.2014 11:57:30 > HW Version: SKT INFO : 13.01.2014 11:57:30 > Phone was not found on the selected port! INFO : 13.01.2014 11:57:30 > Searching for USB diagnostic port... INFO : 13.01.2014 11:57:30 > Connecting to phone on COM39 WARN : 13.01.2014 11:57:34 > Phone connection failed WARN : 13.01.2014 11:57:34 > No diagnostic ports found! INFO : 13.01.2014 11:57:34 > Connecting to phone on COM35 INFO : 13.01.2014 11:57:34 > Mode: Normal INFO : 13.01.2014 11:57:35 > Phone model: SHV-E160S INFO : 13.01.2014 11:57:35 > Firmware compiled date: May 03 2012 INFO : 13.01.2014 11:57:35 > Firmware compiled time: 10:00:00 INFO : 13.01.2014 11:57:35 > Firmware released date: Jul 31 2012 INFO : 13.01.2014 11:57:35 > Firmware released time: 13:16:06 INFO : 13.01.2014 11:57:35 > SW version: M9200B-SCAQCSZD-3.4.706025 INFO : 13.01.2014 11:57:35 > Old IMEI: 000000-00-000000-0 INFO : 13.01.2014 11:57:35 > New IMEI: xxxxxxxxxx INFO : 13.01.2014 11:57:42 > Firmware compiled date: Fri Aug 24 19:23:19 KST 2012 INFO : 13.01.2014 11:57:42 > PDA version: E160S.UH24.1912 INFO : 13.01.2014 11:57:43 > CSC version: Unknown INFO : 13.01.2014 11:57:43 > SW version: E160S.UG31.1316.ST INFO : 13.01.2014 11:57:45 > Phone IMEI: 000000000000000 INFO : 13.01.2014 11:57:45 > Phone SN: 00000000000 INFO : 13.01.2014 11:57:45 > Android version: 4.0.4 (IMM76D) INFO : 13.01.2014 11:57:45 > Deactivating MSL... INFO : 13.01.2014 11:59:06 > MSL deactivate successfully WARN : 13.01.2014 11:59:06 > Phone will restart now. Please don't disconnect cable! INFO : 13.01.2014 11:59:08 > Searching for a phone. Please wait... INFO : 13.01.2014 12:03:09 > Firmware compiled date: May 03 2012 INFO : 13.01.2014 12:03:09 > Firmware compiled time: 10:00:00 INFO : 13.01.2014 12:03:09 > Firmware released date: Jul 31 2012 INFO : 13.01.2014 12:03:09 > Firmware released time: 13:16:06 INFO : 13.01.2014 12:03:09 > SW version: M9200B-SCAQCSZD-3.4.706025 INFO : 13.01.2014 12:03:09 > Repairing IMEI ... INFO : 13.01.2014 12:03:10 > IMEI successfully repaired. WARN : 13.01.2014 12:03:10 > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) INFO : 13.01.2014 12:05:17 > ----------------------------------------------------------------------------------- INFO : 13.01.2014 12:05:17 > Platform: Samsung Anycall INFO : 13.01.2014 12:05:17 > Selected port: COM35 INFO : 13.01.2014 12:05:17 > Selected model: SHV-E160S INFO : 13.01.2014 12:05:17 > Mode: Normal INFO : 13.01.2014 12:05:17 > Phone was not found on the selected port! INFO : 13.01.2014 12:05:17 > Searching for USB diagnostic port... WARN : 13.01.2014 12:05:17 > No diagnostic ports found! INFO : 13.01.2014 12:05:17 > Connecting to phone on COM35 INFO : 13.01.2014 12:05:17 > Mode: Normal INFO : 13.01.2014 12:05:18 > Phone model: SHV-E160S INFO : 13.01.2014 12:05:18 > Firmware compiled date: May 03 2012 INFO : 13.01.2014 12:05:18 > Firmware compiled time: 10:00:00 INFO : 13.01.2014 12:05:18 > Firmware released date: Jul 31 2012 INFO : 13.01.2014 12:05:18 > Firmware released time: 13:16:06 INFO : 13.01.2014 12:05:18 > Phone IMEI: 353267xxxxxxxxx INFO : 13.01.2014 12:05:18 > SW version: M9200B-SCAQCSZD-3.4.706025 INFO : 13.01.2014 12:05:18 > Creating NVM backup INFO : 13.01.2014 12:13:01 > Reading NVM done! INFO : 13.01.2014 12:13:01 > Repairing NVM for SHV-E160S phone... INFO : 13.01.2014 12:13:16 > NVM repair completed successfully WARN : 13.01.2014 12:13:17 > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Phone İnfo Logs: Code: Platform: Samsung Anycall Selected port: COM35 Selected model: SHV-E160S Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM35 Mode: Normal Phone model: SHV-E160S Firmware compiled date: May 03 2012 Firmware compiled time: 10:00:00 Firmware released date: Jul 31 2012 Firmware released time: 13:16:06 Phone IMEI: 353267-xxxxxxxxxxx SW version: M9200B-SCAQCSZD-3.4.706025 |
01-13-2014, 14:37 | #4 (permalink) |
Member: 598417 Status: Offline Thanks Meter: 57 | Write firmware logs: Code: INFO : 13.01.2014 11:13:50 > To connect SHV-E160S phone you have to perform the following steps: INFO : 13.01.2014 11:13:50 > 1. Go to dial window. INFO : 13.01.2014 11:13:50 > 2. Enter "319712358" number. INFO : 13.01.2014 11:13:50 > 3. Enter "996412" password. INFO : 13.01.2014 11:13:50 > 4. Go to System->SIO mode. INFO : 13.01.2014 11:13:50 > 5. Select "Modem" radio button for USB section. INFO : 13.01.2014 11:13:50 > 6. Go to dial window. INFO : 13.01.2014 11:13:50 > 7. Enter "*#9090#" number. INFO : 13.01.2014 11:13:50 > 8. Set "Diag config" to "USB" value. INFO : 13.01.2014 11:13:50 > 9. Restart phone. INFO : 13.01.2014 11:13:50 > 10. Press "Read Info" in software. INFO : 13.01.2014 11:13:54 > Selected firmware file: E160S.UH24.1912_CL966809_REV02_ROOTED.oct WARN : 13.01.2014 11:13:58 > Please switch your phone to the download mode and connect it to a PC. WARN : 13.01.2014 11:13:58 > To put SHV-E160S phone into download mode you have to perform the following steps: WARN : 13.01.2014 11:13:58 > 1. Reconnect phone battery. WARN : 13.01.2014 11:13:58 > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 13.01.2014 11:13:58 > 3. When phone turns on press "Volume+" button. INFO : 13.01.2014 11:13:58 > Found phone on INFO : 13.01.2014 11:13:58 > Firmware write started. INFO : 13.01.2014 11:13:58 > Writing BOOT section... INFO : 13.01.2014 11:14:02 > BOOT section has been written successfully. INFO : 13.01.2014 11:14:02 > Writing RECOVERY section... INFO : 13.01.2014 11:14:05 > RECOVERY section has been written successfully. INFO : 13.01.2014 11:14:05 > Writing MODEM section... INFO : 13.01.2014 11:14:15 > MODEM section has been written successfully. INFO : 13.01.2014 11:14:15 > Writing MDM section... INFO : 13.01.2014 11:14:26 > MDM section has been written successfully. INFO : 13.01.2014 11:14:26 > Writing SYSTEM section... INFO : 13.01.2014 11:18:27 > SYSTEM section has been written successfully. INFO : 13.01.2014 11:18:33 > Firmware writing successfully completed. |
01-13-2014, 15:01 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Please do the next: 1. Close the Software. 2. Delete all logs from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 3. Run the Software again. 4. Make "Repair IMEI". 5. Re-flash the phone. 6. Make "Repair NVM". 7. Close the Software. 8. Upload somewhere the last created "*.log" and "*.logx" files for the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the link, we will research where can be the problem with the phone. |
01-13-2014, 17:12 | #13 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | What was the state of your device before? Quote:
01-13-2014, 17:31 | #15 (permalink) |
Member: 598417 Status: Offline Thanks Meter: 57 | phone SN:00000000 and CSC unknown phone damaged HW? Code: INFO : 13.01.2014 16:20:51 > Platform: Samsung Anycall INFO : 13.01.2014 16:20:51 > Selected port: COM39 INFO : 13.01.2014 16:20:51 > Selected model: SHV-E160S INFO : 13.01.2014 16:20:53 > Detected phone model: SHV-E160S INFO : 13.01.2014 16:20:53 > HW Version: SKT INFO : 13.01.2014 16:20:53 > Phone was not found on the selected port! INFO : 13.01.2014 16:20:53 > Searching for USB diagnostic port... INFO : 13.01.2014 16:20:53 > Connecting to phone on COM39 INFO : 13.01.2014 16:20:54 > Detected phone model: SHV-E160S INFO : 13.01.2014 16:20:54 > HW Version: SKT WARN : 13.01.2014 16:20:54 > Phone connection failed WARN : 13.01.2014 16:20:54 > No diagnostic ports found! INFO : 13.01.2014 16:20:54 > Connecting to phone on COM35 INFO : 13.01.2014 16:20:58 > Mode: Normal INFO : 13.01.2014 16:20:58 > Phone model: SHV-E160S INFO : 13.01.2014 16:20:58 > Firmware compiled date: May 03 2012 INFO : 13.01.2014 16:20:58 > Firmware compiled time: 10:00:00 INFO : 13.01.2014 16:20:58 > Firmware released date: Jul 31 2012 INFO : 13.01.2014 16:20:58 > Firmware released time: 13:16:06 INFO : 13.01.2014 16:20:58 > SW version: M9200B-SCAQCSZD-3.4.706025 INFO : 13.01.2014 16:20:58 > Old IMEI: 353267-01-129499-6 INFO : 13.01.2014 16:20:58 > New IMEI: 353267-01-129493-9 INFO : 13.01.2014 16:21:04 > Firmware compiled date: Fri Aug 24 19:23:19 KST 2012 INFO : 13.01.2014 16:21:05 > PDA version: E160S.UH24.1912 INFO : 13.01.2014 16:21:06 > CSC version: Unknown INFO : 13.01.2014 16:21:06 > SW version: E160S.UG31.1316.ST INFO : 13.01.2014 16:21:07 > Phone IMEI: 353267011294996 INFO : 13.01.2014 16:21:08 > Phone SN: 00000000000 INFO : 13.01.2014 16:21:08 > Android version: 4.0.4 (IMM76D) INFO : 13.01.2014 16:21:08 > Deactivating MSL... INFO : 13.01.2014 16:22:32 > MSL deactivate successfully WARN : 13.01.2014 16:22:32 > Phone will restart now. Please don't disconnect cable! INFO : 13.01.2014 16:22:34 > Searching for a phone. Please wait... INFO : 13.01.2014 16:23:54 > Repairing IMEI ... INFO : 13.01.2014 16:23:55 > IMEI successfully repaired. WARN : 13.01.2014 16:23:55 > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
