12-09-2013, 15:51 | #1 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Earth
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | SHW-M110S_ to_GT_ I9000_fix.tar [Solved] Had 4 Files after extracted *Cache.rfs *Factoryfs.rfs *modem *Zimage Please Guide me to arrange Files to flash !!! Last edited by Octopus box; 12-10-2013 at 13:53. |
12-09-2013, 16:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. No need to extract files from "SHW-M110S_ to_GT_ I9000_fix.tar". You can convert this file by using Firmware converter ("Firmware converter" button in Software) - select this file in PDA slot and convert it into SHW-M110S_ to_GT_ I9000_fix.oct, then write it. Also You can write this file by using original Samsung flasher. |
12-09-2013, 16:39 | #3 (permalink) |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | help me hello team, then i tried to flash Without Extracting the file SHW-M110S_ to_GT_ I9000_fix.tar but it gave me an error Please switch your phone to the download mode and connect it to a PC. Found phone on Firmware write started. Writing Firmware Failed tried several time to flash but it gives the same error & sadly phone hangs on Samsung Upgrade Mode !! Last edited by .::TEAM CCS::.; 12-09-2013 at 16:44. |
12-09-2013, 17:16 | #4 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
12-10-2013, 13:41 | #5 (permalink) | |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Done!!! Quote:
Couldn't realize the Exact Fault, But Suddenly it Detected the Phone & Flashed the Above firmware automatically & now Phone Is working ! Anyway Thanks for your Support. | |
