12-04-2013, 15:48 | #1 (permalink) | |
Freak Poster Join Date: Jan 2013 Location: Pampanga, Philippines
Member: 1871628 Status: Offline Thanks Meter: 22 | SHW-M440S (No Signal/Blank IMEI) Dear Team, Does The Present or Latter GUI Already Supported This Unit for IMEI Repair? Quote:
Thanks in Advance, | |
12-07-2013, 03:43 | #3 (permalink) | ||
Member: 1871628 Status: Offline Thanks Meter: 22 | Quote:
Heres my Update Sir, in writing imei. Quote:
12-07-2013, 09:15 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Most likely, EFS in your device is damaged. Repair EFS is currently not supported for this phone model. You can try to read EFS and Security from another working SHW-M440S and then write into your device. Also, try to search another firmwares and re-flash your device with this firmwares, maybe, this will help. |
12-07-2013, 10:32 | #5 (permalink) |
Member: 1871628 Status: Offline Thanks Meter: 22 | If, i will be lucky to find a good EFS and Security from another working phone (SHW-M440s), and write it. Would there be a chance that the phone will be Fixed Sir? I think its a tough job to find the requirements since most of this phones are not introduced in our Country by Samsung and most of them were only Shipped here given by friends who worked there. |
12-08-2013, 09:21 | #6 (permalink) |
Insane Poster Join Date: Jan 2008 Location: Viet Nam
Member: 667924 Status: Offline Thanks Meter: 25 | If hard to find good dump, you can try backup efs your phone, convert it into I9300 then repair EFS. P/S: I try change emmc M440S then convert I9300 100% ok, so maybe you can try. |
12-09-2013, 04:52 | #7 (permalink) | ||
If luckily it would have or they have, im sure its so expensive. | ||
12-14-2013, 10:21 | #9 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As I can see from this screenshot, there are some problems with your device: modem is not working: Quote:
What is the IMEI in your device (by "*#06#") exactly? | ||
12-15-2013, 09:31 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | At first, try to write different firmwares and check whether phone's modem works (press "Read info" button at "Android / EFS manager" tab in Software and check whether modem info is read out - should be info like here: "SW Version: M440SXXXXX"). When modem will be present, perform Repair IMEI operation. Last edited by Octopus box; 12-15-2013 at 09:41. |
12-15-2013, 15:33 | #12 (permalink) |
Member: 1871628 Status: Offline Thanks Meter: 22 | Links Provided on Octopus Support doesnt all works properly on my Handset only 4.0.4 is booting up properly, the rest of the versions including the new uploaded file (with Pit File) doesnt respond normally with the phone, result is, phone just keeps on rebooting all over again on SKT Logo, except for 4.0.4 version but still write IMEI Fails. |
12-15-2013, 15:38 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Does the modem work with this 4.0.4 version (press "Read info" button at "Android / EFS manager" tab in Software and check whether modem info is read out - should be info like here: "SW Version: M440SXXXXX")? |
12-16-2013, 04:24 | #14 (permalink) |
Member: 1871628 Status: Offline Thanks Meter: 22 | Here is Info on Front Screen Of Phone Sir. PDA: M440SKSALG2 Phone: Unknown CSC: M440SSKTALEE H/W: Unknown RF Cal Date: Unknown SMD:' PBA: RearCAM:, FrontCAM: S5K6A3 S5K6A3 TSP: Oxbd TSK: 0x6 Band: Unknown, CH: Unknown UART: Unknown, USB: Unknown UN: CVTF114CC66905F |
12-16-2013, 07:24 | #15 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Yes, As I have said, modem is not working in your device: Quote:
