07-19-2017, 16:02 | #1 (permalink) |
Freak Poster Join Date: Apr 2017 Location: PakisTan
Member: 2705080 Status: Offline Sonork: 100.1679605 Thanks Meter: 41 | sm-710f installing updats problem i have samsung sm-j710f it have installing update problem i have flsh latest firmwares but same problem . and frp lock also on and when i tried to combination file its showing binnary problem. have any sulotion plz thanks in advance: Last edited by ateeq khan; 07-19-2017 at 16:08. |
07-19-2017, 16:19 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Binary problem during writing of a combination firmware occurs if it is not compatible with current firmware of the phone. If You want to remove FRP lock You can either write older by release date firmware, then perform "Reset FRP" operation and let Software write built-in boot.img partition, or manually write "boot.img" partition of a compatible Combination firmware. |
07-19-2017, 16:25 | #3 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1412183 Status: Offline Thanks Meter: 27 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.6 ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: COMBINATION_OXA_FA60_J710FXXU1APG1 _OXA1APG1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing Firmware Failed Performed by 2.5.6 Software version. Selected BOOT file: I:\SAMSUNG FILE\SAMSUNG ALL FILE ONE BY ONE\J FILE\j710f tested v 6.0.1\SM-J710F_1_20170519202327 _yctamp5uuu_fac\BL_J710FXXU3AQD1_CL10674160_QB1319 4283 _REV03_user_low_ship.tar.md5 Selected AP file: I:\SAMSUNG FILE\SAMSUNG ALL FILE ONE BY ONE\J FILE\j710f tested v 6.0.1\SM-J710F_1_20170519202327 _yctamp5uuu_fac\AP_J710FXXU3AQD1_CL10674160_QB1319 4283 _REV03_user_low_ship.tar.md5 Selected CP file: I:\SAMSUNG FILE\SAMSUNG ALL FILE ONE BY ONE\J FILE\j710f tested v 6.0.1\SM-J710F_1_20170519202327 _yctamp5uuu_fac\CP_J710FXXU3AQD3_CL471751_QB622048 5 _SIGNED.tar.md5 Selected CSC file: I:\SAMSUNG FILE\SAMSUNG ALL FILE ONE BY ONE \J FILE\j710f tested v 6.0.1\SM-J710F_1_20170519202327 _yctamp5uuu_fac\CSC_OJW_J710FOJW3AQD1_CL10674160 _QB13194283_REV03_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CP_DEBUG section... CP_DEBUG section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.5.6 Software version. |
07-19-2017, 17:06 | #5 (permalink) |
Member: 1412183 Status: Offline Thanks Meter: 27 | COMBINATION_OXA_FA60_J710FXXU1AQB3 but same pronlem Performed by 2.5.6 Software version. Selected AP file: I:\SAMSUNG FILE\OCTPLUS BOX FILE\J FILE OCT \COMBINATION_OXA_FA60_J710FXXU1AQB3_OXAFAC_CL75648 64 _QB12537903_REV03_user_mid_noship\COMBINATION_OXA_ FA60 _J710FXXU1AQB3_OXAFAC_CL7564864_QB12537903_REV03 _user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing Firmware Failed Performed by 2.5.6 Software version. |
