03-29-2017, 11:47 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Peshawar
Member: 742615 Status: Offline Thanks Meter: 58 | Sm-925f new security damaged need help [Solved] INFO : 29-Mar-17 3:26:20 PM > Selected port: COM3 INFO : 29-Mar-17 3:26:20 PM > Selected model: SM-G925F INFO : 29-Mar-17 3:26:22 PM > Selected file: G:\Galaxy\SM-G925F\cert\SM-G925F_357460064756989_0346.cert INFO : 29-Mar-17 3:26:26 PM > Detected phone model: SM-G925F INFO : 29-Mar-17 3:26:26 PM > Firmware compiled date: Wed Feb 22 15:33:20 KST 2017 INFO : 29-Mar-17 3:26:26 PM > PDA version: G925FXXU5DQBC INFO : 29-Mar-17 3:26:26 PM > CSC version: G925FOLB4DQB1 INFO : 29-Mar-17 3:26:26 PM > SW version: unknown INFO : 29-Mar-17 3:26:27 PM > Phone SN: RF1D45EJGGR INFO : 29-Mar-17 3:26:27 PM > Android version: 6.0.1 (MMB29K) INFO : 29-Mar-17 3:26:27 PM > Sales code: XXV INFO : 29-Mar-17 3:26:27 PM > Country: VIETNAM INFO : 29-Mar-17 3:26:27 PM > HW platform: exynos5 INFO : 29-Mar-17 3:26:27 PM > HW Chip: exynos7420 INFO : 29-Mar-17 3:26:27 PM > HW Modem: unknown INFO : 29-Mar-17 3:26:27 PM > Security patch level: 2017-02-01 INFO : 29-Mar-17 3:26:27 PM > Codename: zeroltexx INFO : 29-Mar-17 3:26:27 PM > Checking Root: INFO : 29-Mar-17 3:26:27 PM > Phone is Rooted. INFO : 29-Mar-17 3:26:27 PM > Reading security backup, please wait... INFO : 29-Mar-17 3:26:53 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G925F-Unknown29-03-2017_15-26-22-.asec file INFO : 29-Mar-17 3:26:53 PM > Checking Certificate file... INFO : 29-Mar-17 3:26:53 PM > Certificate file successfully checked INFO : 29-Mar-17 3:26:57 PM > Initializing exploit... INFO : 29-Mar-17 3:27:05 PM > OK INFO : 29-Mar-17 3:27:14 PM > Executing exploit... ERROR : 29-Mar-17 3:28:05 PM > Please remove SIM card if it is inserted and try again! ERROR : 29-Mar-17 3:28:05 PM > Executing exploit failed ERROR : 29-Mar-17 3:28:05 PM > Writing Certificate failed INFO : 29-Mar-17 3:28:05 PM > Performed by 2.4.9 Software version. Last edited by Octopus box; 03-29-2017 at 16:18. |
03-29-2017, 11:57 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Write Cert"/"Repair IMEI" operations. It is not possible to repair IMEI, if phone's modem part is damaged. | |
03-29-2017, 12:02 | #3 (permalink) |
Member: 742615 Status: Offline Thanks Meter: 58 | WHEN I REPAIR EFS PHONE BASEBAND BECAME OK BUT WHEN TRYING REPAIR SECURITY THEN IMEI NULL SECURITY REPAIR POSSIBLE (Security patch level: 2017-02-01) ?? I WILL TRY WITH ANOTHER FIRMWARE TOO |
03-29-2017, 12:49 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Your phone has firmware with new type of Security. If You want to write a Cert file - You need to write older by release date firmware, or its modem first. "Repair Security" is not needed to write a Cert file. You can try to use standard "Repair IMEI" operation without downgrading of firmware/modem. |
04-18-2017, 08:42 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Combination firmwares, which we have at the moment, are available in "Samsung/Combination" folder of the Support Area. To access Support Area, press "Go to support" button on "Support & options" tab of the Software. Also You can use Files Downloader on "Support & options" tab of the Software to browse, search and download files from the Support Area. |
