11-12-2017, 18:09 | #1 (permalink) |
Freak Poster Join Date: Aug 2017
Member: 2751525 Status: Offline Thanks Meter: 28 | SM-A310F Read Code done ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A310F Please, press "OK" button on the phone to allow USB debugging.. Certificate read successfully Performed by 2.5.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A310F Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Certificate read successfully Performed by 2.5.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A310F Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SM-A310F Firmware compiled date: Mon Mar 20 21:44:00 KST 2017 PDA version: A310FXXU3BQC8 CSC version: A310FOJV3BQC8 SW version: A310FXXU3BQC8 Phone SN: R28H523MXYB Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7580 HW Modem: SHANNON310 Security patch level: 2017-03-01 SIM 1 status: absent Codename: a3xeltexx Backup saved as file Connecting to modem port... Found phone on COM443 Reading data from phone... Could not read data from modem port, trying with exploit.. Initializing exploit... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Executing exploit... Exploit has been executed successfully Reading Certificate... Checking Certificate file... Phone KeyID: 17 Certificate file successfully checked Certificate read successfully Performed by 2.5.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM443 Selected model: SM-A310F Detected phone model: SM-A310F Firmware compiled date: Mon Mar 20 21:44:00 KST 2017 PDA version: A310FXXU3BQC8 CSC version: A310FOJV3BQC8 SW version: A310FXXU3BQC8 Phone SN: R28H523MXYB Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7580 HW Modem: SHANNON310 Security patch level: 2017-03-01 SIM 1 status: absent Codename: a3xeltexx Checking Root: Phone is Rooted. Connecting to modem port... Found phone on COM443 Reading data from phone... Could not read data from modem port, trying with exploit.. Initializing exploit... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Executing exploit... Exploit has been executed successfully Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 49302635 NET LOCK unlock code: 82968306 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:32 Performed by 2.5.5 Software version. Last edited by Octopus box; 11-13-2017 at 07:00. |
The Following User Says Thank You to GSM.WIZARD For This Useful Post: |
