04-24-2019, 05:27 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: From Uzbekistan
Member: 545722 Status: Offline Sonork: 100.1619680 Thanks Meter: 322 | Sm-a405fn frp help [Answered] combination file pit error youtube too error hushsms and sim card with pin code not help |
05-28-2019, 20:07 | #3 (permalink) |
Major Poster Join Date: Feb 2008
Member: 714472 Status: Offline Thanks Meter: 6 | I would like remove frp on a405fn , but have error ! When i want flahs wiht combination this is error ! I try more flahs sc2 , sc9 ,sd1, always see this, when i try odin 3.13.1 or 3.13.3 re partition error stoping, another box same error ! Can you help me ? Thank you ! Welcome to Octoplus Box Samsung software version 2.8.0.1 Selected firmware file: COMBINATION_FAC_FA90_A405FNXXU1ASC2 _FACFA90_A405FNFAC1ASC2_CL15547963_QB22401955_REV0 0 _user_mid_noship.tar.md5 Selected AP file: C:\sam\A405fn\DS\COMBIN~1.TAR\COMBIN~1.TAR \COMBINATION_FAC_FA90_A405FNXXU1ASC2_FACFA90 _A405FNFAC1ASC2_CL15547963_QB22401955_REV00 _user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-A405FN into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing NAD_FW section... NAD_FW section has been written successfully. Writing Firmware Failed Performed by 2.8.0.1 Software version. End stop 1% |
05-29-2019, 08:23 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares. There are few methods, of how to reset FPR on phones with latest firmwares: I. Try to write SBoot file of older firmware. Repeat "Reset FRP/Reactivation/EE" operation. II. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). Perform "Reset FRP" operation in Software. 74957382 III. Write Full Combination Firmware. Go to "Developer Options" in phone Settings. Check "Enable OEM unlock" option. Make Factory Data Reset. Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! If neither of these methods helps, or necessary files are missing, You can use Factory Reset FRP Service. |
