01-10-2017, 18:35 | #1 (permalink) | |
Freak Poster Join Date: Aug 2015
Member: 2450208 Status: Offline Thanks Meter: 8 | SM-A510FD FRP lock bypass not working? Quote:
any help please Last edited by Octopus box; 01-20-2017 at 14:53. | |
01-11-2017, 08:45 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Removal of FRP lock requires writing of "boot.img" partition of combination firmware. "boot.img" from Combination firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). To remove FRP lock You should try to manually write "boot.img" of different Combination firmwares and when You manage to find the one, that fits current firmware of the phone - perform "Reset FRP" operation. Press "No" when Software will ask You whether to write "boot.img" during the operation. |
01-11-2017, 18:48 | #3 (permalink) | |
Member: 2450208 Status: Offline Thanks Meter: 8 | Quote:
01-11-2017, 19:12 | #4 (permalink) | |
Member: 2450208 Status: Offline Thanks Meter: 8 | okay man u should know this 2 thinks : 1- my phone screen is broken 2- i dont want to lose my data ( i mean i can't flash the whole Combination firmware bucuse they needs to perform a factory reset ) so that's what im planing to do Quote:
and is here any rules to flash combination firmware i mean look at my firmware name : A510FXXU3BPJ8 red color = my firmware security level i found thes three what to use ?? please i need full details about Combination firmware becuse my screen is broken i dont want to make mistakes note : i success before bypass FRP and pattern with Twrp for phone with broken screen | |
01-12-2017, 08:44 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Here are two methods, of how to reset FPR using Combination firmware on phones with latest firmwares: I.
II.
You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! |
01-12-2017, 10:38 | #6 (permalink) | |
phone framware : A510FXXU3BPJ8 Combination firmware : A510FDXXU1APA as u said and as i understand : i should extract my Combination firmware files and upload boot.img to my phone ,, and then reset frp !! right ? what about note ?? u mean when i done reset frp my phone will stuck on logo ? | |
01-12-2017, 10:59 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | "Reset FRP" operation requires enabled ADB on phone. To enable ADB You need to write "boot.img" of Combination firmware. Phone can stuck on logo if "boot.img" of Combination firmware will be not compatible with current firmware of the phone. In such case You'll need to reflash the phone with an original firmware. After writing of an original firmware problem will be fixed and You will be able to try to use another Combination firmware. |
01-15-2017, 11:22 | #8 (permalink) | |
Member: 2450208 Status: Offline Thanks Meter: 8 | i get this error : ....................... Quote:
01-15-2017, 12:26 | #9 (permalink) | |
Member: 2450208 Status: Offline Thanks Meter: 8 | Invalid file format problem solved no i flashed my phone with this file : A510FXXU3BPI9_A510FDODD3BPI2_A510FDXXU3BPJ1_Androi d_6.0.1.oct then i used advanced mode to flash boot.im from COMBINATION_A510FD_user_mid_noship.oct an this is my log : Quote:
what to do ? when i reset frp should i but my phone in download mode ? | |
01-16-2017, 09:12 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @Dr.BL@CKDeaTH This error was already fixed in latest test Software version. Please download and install it from the Support Area ("Samsung/TEST SOFTWARE/" folder) and then repeat "Write Firmware" operation again. Last edited by Octopus box; 01-16-2017 at 09:27. |
01-16-2017, 09:25 | #11 (permalink) | |
Member: 2450208 Status: Offline Thanks Meter: 8 | [QUOTE=Octopus box;12283027]@Dr.BL@CKDeaTH Quote:
01-20-2017, 14:52 | #12 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
01-20-2017, 14:57 | #13 (permalink) | |
the chipset for this model is : Qualcomm MSM8939 Snapdragon 615 | |
