02-01-2015, 10:12 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: dhaka bangladesh
Member: 2156121 Status: Offline Thanks Meter: 36 | Sm-g313hu imei repair problem please help [Solved] SM-G313HU IMEI REPAIR PROBLEM PLEASE HELP.. sm-g313hu/ds imei write problem help octopus team... Platform: Samsung Android Selected port: COM1 Selected model: SM-G313HU Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G313HU Firmware compiled date: Tue Dec 9 21:37:05 KST 2014 PDA version: G313HUXXU0ANL1 CSC version: G313HUOJV0ANL1 SW version: G313HUXXU0ANK1 Phone IMEI: 353976060261355 Phone SN: R21F82AY8TH Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Write IMEI failed DOWNLOAD OCTOPUS SERVER ROOT FILE AND WRITE ROOT FILE THEN SET IS BLINK HELP ME OCTOPUS TEAM... Last edited by Octopus box; 02-02-2015 at 13:40. |
02-01-2015, 10:29 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Make Factory data reset, wipe cache partition and write another firmware, most likely, root file, that You have written is not suitable to your phone's firmware. |
02-01-2015, 10:42 | #3 (permalink) |
Member: 2156121 Status: Offline Thanks Meter: 36 | To connect SM-G313HU phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G313HUDDU0ANH2_ROOT.oct Please put the phone into Download Mode and connect USB cable. To put SM-G313HU into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Firmware writing successfully completed. WRITE ANOTHER FIRMWARE THEN WRITE ROOT FILE THEN ONLY SAMSUNG LOGO....HELP ME OCTOPUS TEAM.... GIVE ME PERFECT ROOT FILE OCTOPUS TEAM BOOSS....... |
02-01-2015, 10:51 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As I have written above, most likely, root file, that You have written is not suitable to your phone's firmware. Unfortunately, currently we have no another rooting Software/exploit for this device. Try to write this root file again, then make Factory data reset and wipe cache partition and try to power the phone on, maybe, this will help. If this will not help - try to find another root. |
02-01-2015, 12:17 | #6 (permalink) |
Member: 2156121 Status: Offline Thanks Meter: 36 | Platform: Samsung Android Selected port: COM1 Selected model: SM-G313HU Detected phone model: SM-G313HU Firmware compiled date: Tue Dec 9 21:37:05 KST 2014 PDA version: G313HUXXU0ANL1 CSC version: G313HUOJV0ANL1 SW version: G313HUXXU0ANK1 Phone IMEI: 353976060261355 Phone SN: R21F82AY8TH Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Writing new IMEI. Please wait... Repairing network. Please wait, this can take some time... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) write success but same imei running help octopus team... |
02-01-2015, 12:29 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to write IMEI Certificates for SM-G313HZ/ML from the Support Area and post here the result, whether IMEI was changed. Also please say, how You have rooted your phone exactly. |
02-01-2015, 13:39 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Do the next: 1. Install the latest Software version (Software). 2. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 3. Take out SIM and SD cards from the device. 4. Run the Software. 5. Make Factory data reset and wipe cache partition. 6. Root the phone. 7. Make Repair IMEI. 8. Close the Software. 9. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the links, we will research, where can be the problem with your device. Also, write here, how You have rooted your phone exactly. |
02-01-2015, 14:35 | #10 (permalink) |
Member: 2156121 Status: Offline Thanks Meter: 36 | Platform: Samsung Android Selected port: COM1 Selected model: SM-G313HU Detected phone model: SM-G313HU Firmware compiled date: Tue Dec 9 21:37:05 KST 2014 PDA version: G313HUXXU0ANL1 CSC version: G313HUOJV0ANL1 SW version: G313HUXXU0ANK1 Phone IMEI: 353976060261355 Phone SN: R21F82AY8TH Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Writing new IMEI. Please wait... Repairing network. Please wait, this can take some time... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) i root successfull but not sure root was perfect..... please send full root firmware i wanna try......help me.. |
02-02-2015, 08:22 | #12 (permalink) |
Member: 2156121 Status: Offline Thanks Meter: 36 | Platform: Samsung Android Selected port: COM1 Selected model: SM-G313HU Detected phone model: SM-G313HU Firmware compiled date: Tue Dec 9 21:37:05 KST 2014 PDA version: G313HUXXU0ANL1 CSC version: G313HUOJV0ANL1 SW version: G313HUXXU0ANK1 Phone IMEI: 353976060261355 Phone SN: R21F82AY8TH Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Writing new IMEI. Please wait... Repairing network. Please wait, this can take some time... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) 1 to 9 step try result same help.... |
