04-22-2015, 19:01 | #1 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1414809 Status: Offline Thanks Meter: 155 | SM-G386T Galaxy Avant unlock solution here! No need to flash entire metropcs firmware. Phone will be unlocked even with tmobile firmware. Credits goes to user "F_X" for giving me the idea. Last edited by Octopus box; 09-23-2018 at 10:01. |
The Following 4 Users Say Thank You to ElBerryKM13 For This Useful Post: |
04-23-2015, 16:14 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to re-flash with the firmwares from the Support Area, folder "Samsung/FOR UNLOCK AND REPAIR/SM-G386T/" and then repeat the Unlock operation again. |
05-14-2015, 07:37 | #10 (permalink) |
Freak Poster Join Date: May 2013
Member: 1947667 Status: Offline Thanks Meter: 31 | Flashed with support area file, using octopus Samsung software. Flashed went well. After reboot , there is this message on screen. Is there some missing step to finally unlock this model? |
05-14-2015, 08:32 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Re-flash the phone with MetroPCS firmware from "Samsung/FOR UNLOCK AND REPAIR/SM-G386T/" folder in the Support Area and then perform "Unlock" operation again. Post here full Software log of performed operations. |
05-14-2015, 10:07 | #13 (permalink) | |
Insane Poster Join Date: Jul 2006 Location: Ghana, Akyem Oda
Member: 321632 Status: Offline Thanks Meter: 21 | Quote:
Please any guide again to solve this problem? Thanks | |
05-14-2015, 10:49 | #15 (permalink) |
Member: 321632 Status: Offline Thanks Meter: 21 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.5 ----------------------------------------------------------------------------------- To connect SM-G386T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM77 Selected model: SM-G386T Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM80 Mode: Normal Phone model: SM-G386T Firmware compiled date: Jul 24 2014 Firmware compiled time: 05:00:00 Firmware released date: Aug 5 2014 Firmware released time: 16:43:38 Phone IMEI: 352829-06-011174-3 SW version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM80 Selected model: SM-G386T Port is busy Mode: Emergency NVM can’t be repaired for SM-G386T phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM80 Selected model: SM-G386T Mode: Normal Phone model: SM-G386T Firmware compiled date: Jul 24 2014 Firmware compiled time: 05:00:00 Firmware released date: Aug 5 2014 Firmware released time: 16:43:38 Phone IMEI: 352829-06-0xxxxxxxxx SW version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM80 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Jul 24 2014 Firmware compiled time: 05:00:00 Firmware released date: Aug 5 2014 Firmware released time: 16:43:38 SW Version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Warning: Selected model (SM-G386T) differs from the detected one (SM-G386T1)! If you want select (SM-G386T1) as (SM-G386T) model, please check "manual select". Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM80 Selected model: SM-G386T Mode: Normal Phone model: SM-G386T Firmware compiled date: Jul 24 2014 Firmware compiled time: 05:00:00 Firmware released date: Aug 5 2014 Firmware released time: 16:43:38 Phone IMEI: 352829-06-0xxxxxxxxxx SW version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 Creating NVM backup Reading NVM done! Repairing NVM for SM-G386T phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
The Following 3 Users Say Thank You to mafolk For This Useful Post: |
