05-14-2015, 11:08 | #16 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | 1. Make Factory Reset 2. Re-flash the phone with "samsung-galaxy-avant-gt386t-metropcs-firmware" firmware from the Support Area again. 3. Repeat "Unlock" operation. Restart the phone via phone's menu as operation ends, this is important. 4. Turns on the phone, wait 3-5 minutes and try to select network manually. |
05-14-2015, 12:31 | #17 (permalink) | |
Insane Poster Join Date: Jul 2006 Location: Ghana, Akyem Oda
Member: 321632 Status: Offline Thanks Meter: 21 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.9.5 ----------------------------------------------------------------------------------- To connect SM-G386T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM77 Selected model: SM-G386T Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM377 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM77 Selected model: SM-G386T Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM81 Port is busy Connecting to phone on COM80 Mode: Normal Phone model: SM-G386T Firmware compiled date: Jul 24 2014 Firmware compiled time: 05:00:00 Firmware released date: Aug 5 2014 Firmware released time: 16:43:38 Phone IMEI: 352829-06-xxxxxxxxxxx SW version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM80 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Jul 24 2014 Firmware compiled time: 05:00:00 Firmware released date: Aug 5 2014 Firmware released time: 16:43:38 SW Version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 Please, press "OK" button on the phone to allow USB debugging.. Warning: Selected model (SM-G386T) differs from the detected one (SM-G386T1)! If you want select (SM-G386T1) as (SM-G386T) model, please check "manual select". Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Please, i have perfomed again the operational steps but still phone is showing searching. | |
05-14-2015, 12:34 | #18 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Read QCN from another, correctly working SM-G386T1 phone and write it into your phone. |
07-24-2015, 23:23 | #22 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: Dhaka, Bangladesh.
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Quote:
07-25-2015, 00:49 | #23 (permalink) | |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Quote:
The Following User Says Thank You to F_X For This Useful Post: |
09-12-2015, 10:07 | #25 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | To Unlock SM-G386T phone, reflash it with "samsung-galaxy-avant-gt386t-metropcs-firmware" firmware from the Support Area (file is available in "samsung/for unlock and repair/sm-g386t/" folder of the Support Area), then perform "Unlock" operation. |
03-16-2016, 10:47 | #28 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | No, You don't need to root the phone for an "Unlock" operation. |
04-11-2016, 08:02 | #29 (permalink) | |
Junior Member Join Date: Jul 2014
Member: 2229337 Status: Offline Thanks Meter: 0 | Quote:
