05-01-2015, 07:26 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: INDIA
Member: 130050 Status: Offline Thanks Meter: 83 | SM-G386T Unlock problem [Solved] to i try g386t for unlock but phone still locked...... after try to reflash with " SM-G386T_modem_for_direct_unlock.oct " but no luck !!!!!!!!!!!!!! See My LOG : Code: Welcome to Octoplus/Octopus Box Samsung software version 1.9.4 ----------------------------------------------------------------------------------- To connect SM-G386T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G386T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM44 Mode: Normal Phone model: SM-G386T Firmware compiled date: Aug 07 2014 Firmware compiled time: 22:00:00 Firmware released date: Nov 26 2014 Firmware released time: 09:43:25 Phone IMEI: 352829-06-424385-6 SW version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM44 Selected model: SM-G386T Reading info, please wait... Detected phone model: SM-G386T Firmware compiled date: Wed Nov 26 17:55:35 KST 2014 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 SW version: G386TUVU1ANK3 Phone IMEI: 352829064243856 Phone SN: R28F917D75J Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM44 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Aug 07 2014 Firmware compiled time: 22:00:00 Firmware released date: Nov 26 2014 Firmware released time: 09:43:25 SW Version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 Detected phone model: SM-G386T Firmware compiled date: Wed Nov 26 17:55:35 KST 2014 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 SW version: G386TUVU1ANK3 Phone IMEI: 352829064243856 Phone SN: R28F917D75J Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Selected firmware file: SM-G386T_modem_for_direct_unlock.oct Please put the phone into Download Mode and connect USB cable. To put SM-G386T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Aug 07 2014 Firmware compiled time: 22:00:00 Firmware released date: Nov 26 2014 Firmware released time: 09:43:25 SW Version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 Detected phone model: SM-G386T Firmware compiled date: Wed Nov 26 17:55:35 KST 2014 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 SW version: G386TUVU1ANK3 Phone IMEI: 352829064243856 Phone SN: R28F917D75J Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Last edited by Octopus box; 05-01-2015 at 13:47. |
05-01-2015, 07:38 | #2 (permalink) |
Freak Poster Join Date: Apr 2015 Location: IN INDIA
Member: 2372600 Status: Offline Sonork: 100.1663659,ICQ-670897523 Thanks Meter: 49 | Hi, try to re-flash with other firmware and unlock again |
The Following User Says Thank You to Octopusindia For This Useful Post: |
05-01-2015, 08:20 | #3 (permalink) |
Member: 130050 Status: Offline Thanks Meter: 83 | same problem still dear, after reflash with " G386TUVU1ANHA_G386TTMB1ANHA_TMB_Android_4.4.2.oct " Still LOCKED Code: Welcome to Octoplus/Octopus Box Samsung software version 1.9.4 ----------------------------------------------------------------------------------- To connect SM-G386T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G386T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM44 Mode: Normal Phone model: SM-G386T Firmware compiled date: Aug 07 2014 Firmware compiled time: 22:00:00 Firmware released date: Nov 26 2014 Firmware released time: 09:43:25 Phone IMEI: 352829-06-424385-6 SW version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM44 Selected model: SM-G386T Reading info, please wait... Detected phone model: SM-G386T Firmware compiled date: Wed Nov 26 17:55:35 KST 2014 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 SW version: G386TUVU1ANK3 Phone IMEI: 352829064243856 Phone SN: R28F917D75J Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM44 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Aug 07 2014 Firmware compiled time: 22:00:00 Firmware released date: Nov 26 2014 Firmware released time: 09:43:25 SW Version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 Detected phone model: SM-G386T Firmware compiled date: Wed Nov 26 17:55:35 KST 2014 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 SW version: G386TUVU1ANK3 Phone IMEI: 352829064243856 Phone SN: R28F917D75J Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Selected firmware file: SM-G386T_modem_for_direct_unlock.oct Please put the phone into Download Mode and connect USB cable. To put SM-G386T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Aug 07 2014 Firmware compiled time: 22:00:00 Firmware released date: Nov 26 2014 Firmware released time: 09:43:25 SW Version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 Detected phone model: SM-G386T Firmware compiled date: Wed Nov 26 17:55:35 KST 2014 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 SW version: G386TUVU1ANK3 Phone IMEI: 352829064243856 Phone SN: R28F917D75J Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Selected firmware file: G386TUVU1ANHA_G386TTMB1ANHA_TMB_Android_4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-G386T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G386T Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G386T Firmware compiled date: Fri Aug 22 18:43:54 KST 2014 PDA version: G386TUVU1ANHA CSC version: G386TTMB1ANHA SW version: G386TUVU1ANHA Phone IMEI: 352829064243856 Phone SN: R28F917D75J Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Aug 07 2014 Firmware compiled time: 22:00:00 Firmware released date: Aug 22 2014 Firmware released time: 14:03:37 SW Version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 Detected phone model: SM-G386T Firmware compiled date: Fri Aug 22 18:43:54 KST 2014 PDA version: G386TUVU1ANHA CSC version: G386TTMB1ANHA SW version: G386TUVU1ANHA Phone IMEI: 352829064243856 Phone SN: R28F917D75J Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Selected firmware file: SM-G386T_modem_for_direct_unlock.oct Please put the phone into Download Mode and connect USB cable. To put SM-G386T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Aug 07 2014 Firmware compiled time: 22:00:00 Firmware released date: Aug 22 2014 Firmware released time: 14:03:37 SW Version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 Detected phone model: SM-G386T Firmware compiled date: Fri Aug 22 18:43:54 KST 2014 PDA version: G386TUVU1ANHA CSC version: G386TTMB1ANHA SW version: G386TUVU1ANHA Phone IMEI: 352829064243856 Phone SN: R28F917D75J Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
05-01-2015, 10:57 | #6 (permalink) |
Member: 2372600 Status: Offline Sonork: 100.1663659,ICQ-670897523 Thanks Meter: 49 | HI, Samsung made permanent locked firmware same as TELCEL maxico before.. G925T is one of them and others G368T,G925T WAIT FOR NEXT UPDATE ALL ISSU SOLVE IN NEXT UPDATE |
05-01-2015, 11:06 | #8 (permalink) |
Member: 2372600 Status: Offline Sonork: 100.1663659,ICQ-670897523 Thanks Meter: 49 | Hi, try with own risk, and read nvm,efs and all backup your mobile before flash |
05-01-2015, 11:50 | #9 (permalink) |
Member: 130050 Status: Offline Thanks Meter: 83 | WOW UNLOCK DONE !!!!! After flash with sm-g386t1......... Thank You Octopus India & Mr. " tccnizmozr "........ And All is Working Fine with Original imei.... |
The Following 4,294,967,295 Users Say Thank You to Devashish Mobile For This Useful Post: |
