10-19-2017, 14:33 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: pakistan
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | SM-G530F IMEI Cert Write failed [Answered] ----------------------------------------------------------------------------------- To connect SM-G530F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM81 Selected model: SM-G530F Selected file: C:\Users\123\Desktop\Cert-SM-G530F_355965060136244 _R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Selected file: C:\Users\123\Desktop\Cert-SM-G530F_355965060136244 _R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM4 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed Performed by 2.6.0 Software version. Last edited by Octopus box; 10-19-2017 at 15:22. |
10-19-2017, 14:38 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
Please, try to write another cert file. Also, please perform Read info operation and post here full Software log. | |
10-19-2017, 15:36 | #3 (permalink) |
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | Welcome to Octoplus/Octopus Box Samsung software version 2.6.0 ----------------------------------------------------------------------------------- To connect SM-G530F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530F Reading info... Mode: Normal Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 SW Version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530F Reading info... Mode: Normal Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 SW Version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Reseting MSL... MSL reset successfully. Please, restart the phone to apply changes Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM81 Mode: Normal Phone model: SM-G530F Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 Incorrect IMEI SW version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM81 Selected model: SM-G530F Mode: Normal Phone model: SM-G530F Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 Incorrect IMEI SW version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM81 Selected model: SM-G530F Selected file: C:\Users\123\Desktop\Cert-SM-G530F_355965060136244 _R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Selected file: C:\Users\123\Desktop\Cert-SM-G530F_355965060136244 _R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM4 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Reading info, please wait... Detected phone model: SM-G530F Firmware compiled date: Thu May 28 19:13:12 KST 2015 PDA version: G530FXXU1AOE2 CSC version: G530HSER2AOE5 SW version: G530HXXU2AOE5 Phone SN: R31F501H9NP Android version: 4.4.4 (KTU84P) Sales code: SER Country: Russia HW platform: msm8916 HW Chip: MSM8216 HW Modem: MSM8216 SIM 1 status: ready Codename: fortunaltexx Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Selected file: C:\Users\123\Desktop\SM-G530H RIPON\Cert_SM-G530H_ 355677060467699_double.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM4 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Reading info... Phone was not found on the selected port! Writing QCN failed Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Mode: Emergency NVM can’t be written for SM-G530F phone in emergency mode Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Mode: Emergency NVM can’t be written for SM-G530F phone in emergency mode Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM81 Mode: Normal Phone model: SM-G530F Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 Phone IMEI: 355677-06-046769-9 SW version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM81 Selected model: SM-G530F Detected phone model: SM-G530F Firmware compiled date: Thu May 28 19:13:12 KST 2015 PDA version: G530FXXU1AOE2 CSC version: G530HSER2AOE5 SW version: G530HXXU2AOE5 Phone IMEI: 355677060467699 Phone SN: R31F501H9NP Android version: 4.4.4 (KTU84P) Sales code: SER Country: Russia HW platform: msm8916 HW Chip: MSM8216 HW Modem: MSM8216 SIM 1 status: ready Codename: fortunaltexx Reading info... Mode: Normal Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 SW Version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G530F-355677060467699-19-10-2017_19-00- 20-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G530F-355677060467699-19-10-2017_19-00- 21-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Mode: Normal Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 SW Version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM81 Selected model: SM-G530F Reading info... Mode: Normal Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 SW Version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Detected phone model: SM-G530F Firmware compiled date: Thu May 28 19:13:12 KST 2015 PDA version: G530FXXU1AOE2 CSC version: G530HSER2AOE5 SW version: G530HXXU2AOE5 Phone SN: R31F501H9NP Android version: 4.4.4 (KTU84P) Sales code: SER Country: Russia HW platform: msm8916 HW Chip: MSM8216 HW Modem: MSM8216 SIM 1 status: ready Codename: fortunaltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-G530F-19-10-2017_19-27-10 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM81 Selected model: SM-G530F Selected file: C:\Users\123\Desktop\Cert-SM-G530F_355965060136244 _R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM4 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Selected file: C:\Users\123\Desktop\SM-G530F cert file\SM-G530F cert file\SM-G530F\Cert-SM-G530F_95_355965060136244_95 _R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM4 Phone connected successfully Checking Certificate file... Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Reading info... Phone was not found on the selected port! Operation was failed! Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Reading info... Mode: Normal Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 SW Version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Reseting MSL... MSL reset successfully. Please, restart the phone to apply changes Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM81 Mode: Normal Phone model: SM-G530F Firmware compiled date: May 07 2015 Firmware compiled time: 21:00:00 Firmware released date: May 28 2015 Firmware released time: 18:17:19 Incorrect IMEI SW version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1 Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM81 Selected model: SM-G530F Selected file: C:\Users\123\Desktop\SM-G530H RIPON\SM-G530H RIPON.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM4 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G530F Reading info, please wait... Detected phone model: SM-G530F Firmware compiled date: Thu May 28 19:13:12 KST 2015 PDA version: G530FXXU1AOE2 CSC version: G530HSER2AOE5 SW version: G530HXXU2AOE5 Phone IMEI: 000000015856784 Phone SN: R31F501H9NP Android version: 4.4.4 (KTU84P) Sales code: SER Country: Russia HW platform: msm8916 HW Chip: MSM8216 HW Modem: MSM8216 SIM 1 status: ready Codename: fortunaltexx Performed by 2.6.0 Software version. |
10-19-2017, 15:39 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, reflash the phone with another firmware, after repeat Write Cert operation according to the Software manual. |
