06-14-2016, 09:50 | #1 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | SM-G531F, ALL BKP DONE, READ CERT, WRITE CERT, ROOT INSIDE, SUCCESS by OCTOPUS ROOT: G531FXXU1AOH1_Prerooted_System_v5.1.1_Fixed.zip NOTE: First of write "Prerootted Fw", do a Wipe Data/Factory Reset from phone in "Recovery Mode", (Vol +, Home, Power), Write "Prerootted Fw", ENABLE "UNKNOWN SOURCE" from Setting, "ENABLE OEM UNLOCK" and "ENABLE USB DEBUG". Phone ask for SU Update Binary in Normal mode or by TWRP, click "NORMAL MODE", All Ok Now G531F is Rootted IMPORTANT: If from Dial/Diag Windows, any command like *#0808#, *#0011# itc... not work, NOT WORRY, there's MTP Enabled and can Continue doing all operaction you want, Unlock, Write Cert, itc... LOG: Quote:
Do other Wipe/factory Reset from Recovery Mode and Write one Stock Fw of you Choise, all turn back working Perfect and you Work is Done with Full SUCCESS BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
