03-17-2016, 19:49 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | SM G531F remove google account with success by selecting G531H here is info : Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.2 ----------------------------------------------------------------------------------- To connect SM-G531H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM49 Selected model: SM-G531H To put SM-G531H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.2.2 software version Last edited by Octopus box; 03-18-2016 at 11:58. |
09-14-2016, 08:47 | #3 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Budapest
Member: 472482 Status: Offline Thanks Meter: 105 | Welcome to Octoplus/Octopus Box Samsung software version 2.3.3 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G531F To put SM-G531F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.3.3 software version ----------------------------------------------------------------------------------- I have problem, i see succes remove google account , but not do it, also the phone have google account, not remove it ,why? ?How solve it ? Thanks |
09-14-2016, 08:51 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | @dominik1 Hello. Please, install the latest Software version, then repeat Reset FRP operation again and post here Software log. |
09-14-2016, 09:26 | #5 (permalink) |
Member: 472482 Status: Offline Thanks Meter: 105 | Welcome to Octoplus/Octopus Box Samsung software version 2.3.6 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G531F To put SM-G531F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.3.6 software version ----------------------------------------------------------------------------------- I try but same problem,the account not removed maybe something wrong in the air ,suggestion for this? what try? Thank you |
09-14-2016, 09:30 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to write Sboot of an older (by release date) firmware via "Write Firmware" operation, with enabled "Advanced Mode" option, then repeat "Reset FRP/Reactivation/EE" operation. |
