03-17-2018, 04:13 | #1 (permalink) |
Freak Poster Join Date: Oct 2009 Location: Nepal
Member: 1132141 Status: Offline Thanks Meter: 24 | SM-G532G hangs on logo only [Answered] --wiping data... Formatting /data... E:failed to mount /efs (Invalid argument) Formatting /cache... --set factory reset done... E:failed to mount /efs (Invalid argument) E:failed to mount /efs (Invalid argument) Data wipe complete. and... just hangs on logo only... P.S. I don't have any backup of efs or anything like that... Last edited by Octopus box; 03-19-2018 at 06:28. |
The Following User Says Thank You to acharyabhumi For This Useful Post: |
03-17-2018, 06:56 | #3 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Online Thanks Meter: 5,806 | flash stock firmware www . sammobile . com/firmwares/ssp/SM-G532G/CAM/download/G532GDXU1AQF3/186703/ |
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
03-17-2018, 08:15 | #5 (permalink) |
Member: 1132141 Status: Offline Thanks Meter: 24 | already flashed these two files: G532GDXU1APK4_G532GZZT1APK4_ZZT_Android_6.0.1.oct G532GDXU1APL1_G532GDXU1APK3_G532GOLB1APK3_OLB_Andr oid_6.0.1_2.oct but no luck... haven't tried writing efs... will try and post result |
03-17-2018, 09:58 | #9 (permalink) | |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Quote:
https://www.4shared.com/zip/ND_SFmdpei/efs-G532F.html Last edited by Octopus box; 03-17-2018 at 11:19. | |
The Following 5 Users Say Thank You to -Mosin- For This Useful Post: |
03-17-2018, 12:27 | #10 (permalink) | |
Member: 1132141 Status: Offline Thanks Meter: 24 | Quote:
you have provided efs of g532f, but I have g532g, are you sure it is compatible? | |
03-18-2018, 06:29 | #12 (permalink) |
Member: 1132141 Status: Offline Thanks Meter: 24 | how can I write EFS to the handset with octopus? as it is hang on samsung logo... and octopus asks for handset with USB Debugging on... octopus Log: --------------- Welcome to Octoplus Box Samsung software version 2.6.6 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G532G Operation: Write EFS Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing EFS failed. Performed by 2.6.6 Software version. |
03-18-2018, 16:23 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. You can write this EFS backup "EFS-SM-G532F.tar" via Download Mode. Do the following steps: 1. Select "SM-G532G" in the list of Software. 2. Check (select) "Original Sam. firm. (*.tar)" option next to "Write Firmware" button. 3. Select EFS file "EFS-SM-G532F.tar" and press "Write Firmware" button. |
The Following 5 Users Say Thank You to Octopus box For This Useful Post: |
03-19-2018, 03:49 | #14 (permalink) | |
03-19-2018, 04:33 | #15 (permalink) |
Member: 1132141 Status: Offline Thanks Meter: 24 | flashed "EFS-SM-G532F.tar" ,, now the handset is switched on but... -emergency calls only/ No network connection -no recovery menu (vol+ & home & power key combination not working) -not working *#06#, *#0808# or other commands like this. (but there is showing original IMEI inside setting> about device> IMEI) and showing notification "unauthorised activity detected, restart" after restart, showing recovery menu. after clicking on "wipe data" --dm-verity verification failed... need to check DRK first.. data wipe complete. after completing hard reset, the above listed problems are not solved... |
