12-05-2017, 15:42 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | SM-G570F FRP lock reseted by UART method FRP PREVENTED SCREEN LOCK REMOVE VIA ANOTHER TOOL SO BY UFS METHOD FRP LOCK REMOVED Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\05-12-2017_17-16-18.log" created (05/12/2017 05:16:21 م). INFO : 05/12/2017 05:16:35 م > Set up system language English (file: English.ini) INFO : 05/12/2017 05:16:35 م > Welcome to Octoplus Box Samsung software version 2.6.2 INFO : 05/12/2017 05:17:12 م > ----------------------------------------------------------------------------------- INFO : 05/12/2017 05:17:12 م > To connect SM-G570F phone you have to perform the following steps: INFO : 05/12/2017 05:17:12 م > 1. Disconnect USB cable from phone. INFO : 05/12/2017 05:17:12 م > 2. Go to Menu->Settings->More->About Device. INFO : 05/12/2017 05:17:12 م > 3.Tap on "Build number" 7 times to enable developer options. INFO : 05/12/2017 05:17:12 م > 4. Go to Menu->Settings->More->Developer options. INFO : 05/12/2017 05:17:12 م > 5. Turn on "USB Debugging" option. INFO : 05/12/2017 05:17:18 م > ----------------------------------------------------------------------------------- INFO : 05/12/2017 05:17:18 م > To connect GT-I8262 phone you have to perform the following steps: INFO : 05/12/2017 05:17:18 م > 1. Disconnect USB cable from phone. INFO : 05/12/2017 05:17:18 م > 2. Go to Menu->Settings->More->About Device. INFO : 05/12/2017 05:17:18 م > 3.Tap on "Build number" 7 times to enable developer options. INFO : 05/12/2017 05:17:18 م > 4. Go to Menu->Settings->More->Developer options. INFO : 05/12/2017 05:17:18 م > 5. Turn on "USB Debugging" option. INFO : 05/12/2017 05:17:18 م > 6. Go to dial window. INFO : 05/12/2017 05:17:18 م > 7. Enter "*#0808#" number. INFO : 05/12/2017 05:17:18 م > 8. Select "DM+Modem+ADB". INFO : 05/12/2017 05:17:18 م > 9. Press Home button. INFO : 05/12/2017 05:17:18 م > 10. Go to dial window. INFO : 05/12/2017 05:17:18 م > 11. Enter "*#9090# or *#0808#" number. INFO : 05/12/2017 05:17:18 م > 12. Set "Diag config" to "USB" value. INFO : 05/12/2017 05:17:18 م > 13. Restart phone. INFO : 05/12/2017 05:17:18 م > 14. Press "Read Info" in software. INFO : 05/12/2017 05:17:21 م > ----------------------------------------------------------------------------------- INFO : 05/12/2017 05:17:21 م > To connect SM-G570F phone you have to perform the following steps: INFO : 05/12/2017 05:17:21 م > 1. Disconnect USB cable from phone. INFO : 05/12/2017 05:17:21 م > 2. Go to Menu->Settings->More->About Device. INFO : 05/12/2017 05:17:21 م > 3.Tap on "Build number" 7 times to enable developer options. INFO : 05/12/2017 05:17:21 م > 4. Go to Menu->Settings->More->Developer options. INFO : 05/12/2017 05:17:21 م > 5. Turn on "USB Debugging" option. INFO : 05/12/2017 05:17:22 م > ----------------------------------------------------------------------------------- INFO : 05/12/2017 05:17:22 م > To connect GT-I8262 phone you have to perform the following steps: INFO : 05/12/2017 05:17:22 م > 1. Disconnect USB cable from phone. INFO : 05/12/2017 05:17:22 م > 2. Go to Menu->Settings->More->About Device. INFO : 05/12/2017 05:17:22 م > 3.Tap on "Build number" 7 times to enable developer options. INFO : 05/12/2017 05:17:22 م > 4. Go to Menu->Settings->More->Developer options. INFO : 05/12/2017 05:17:22 م > 5. Turn on "USB Debugging" option. INFO : 05/12/2017 05:17:22 م > 6. Go to dial window. INFO : 05/12/2017 05:17:22 م > 7. Enter "*#0808#" number. INFO : 05/12/2017 05:17:22 م > 8. Select "DM+Modem+ADB". INFO : 05/12/2017 05:17:22 م > 9. Press Home button. INFO : 05/12/2017 05:17:22 م > 10. Go to dial window. INFO : 05/12/2017 05:17:22 م > 11. Enter "*#9090# or *#0808#" number. INFO : 05/12/2017 05:17:22 م > 12. Set "Diag config" to "USB" value. INFO : 05/12/2017 05:17:22 م > 13. Restart phone. INFO : 05/12/2017 05:17:22 م > 14. Press "Read Info" in software. INFO : 05/12/2017 05:17:22 م > ----------------------------------------------------------------------------------- INFO : 05/12/2017 05:17:22 م > To connect SM-G570F phone you have to perform the following steps: INFO : 05/12/2017 05:17:22 م > 1. Disconnect USB cable from phone. INFO : 05/12/2017 05:17:22 م > 2. Go to Menu->Settings->More->About Device. INFO : 05/12/2017 05:17:22 م > 3.Tap on "Build number" 7 times to enable developer options. INFO : 05/12/2017 05:17:22 م > 4. Go to Menu->Settings->More->Developer options. INFO : 05/12/2017 05:17:22 م > 5. Turn on "USB Debugging" option. INFO : 05/12/2017 05:17:35 م > Connecting to server.. INFO : 05/12/2017 05:17:35 م > Username: INFO : 05/12/2017 05:17:35 م > Authorization.. ERROR : 05/12/2017 05:17:35 م > Login error: Wrong username! INFO : 05/12/2017 05:17:35 م > Performed by 2.6.2 Software version. INFO : 05/12/2017 05:17:40 م > Selected interface: UART INFO : 05/12/2017 05:17:40 م > Note: Type *#0*# on the phone and connect UART cable. INFO : 05/12/2017 05:17:40 م > Searching for device. Please wait... ERROR : 05/12/2017 05:17:47 م > Device not found! ERROR : 05/12/2017 05:17:47 م > Operation was cancelled! INFO : 05/12/2017 05:17:47 م > Performed by 2.6.2 Software version. INFO : 05/12/2017 05:19:07 م > ----------------------------------------------------------------------------------- INFO : 05/12/2017 05:19:07 م > To connect GT-I8262 phone you have to perform the following steps: INFO : 05/12/2017 05:19:07 م > 1. Disconnect USB cable from phone. INFO : 05/12/2017 05:19:07 م > 2. Go to Menu->Settings->More->About Device. INFO : 05/12/2017 05:19:07 م > 3.Tap on "Build number" 7 times to enable developer options. INFO : 05/12/2017 05:19:07 م > 4. Go to Menu->Settings->More->Developer options. INFO : 05/12/2017 05:19:07 م > 5. Turn on "USB Debugging" option. INFO : 05/12/2017 05:19:07 م > 6. Go to dial window. INFO : 05/12/2017 05:19:07 م > 7. Enter "*#0808#" number. INFO : 05/12/2017 05:19:07 م > 8. Select "DM+Modem+ADB". INFO : 05/12/2017 05:19:07 م > 9. Press Home button. INFO : 05/12/2017 05:19:07 م > 10. Go to dial window. INFO : 05/12/2017 05:19:07 م > 11. Enter "*#9090# or *#0808#" number. INFO : 05/12/2017 05:19:07 م > 12. Set "Diag config" to "USB" value. INFO : 05/12/2017 05:19:07 م > 13. Restart phone. INFO : 05/12/2017 05:19:07 م > 14. Press "Read Info" in software. INFO : 05/12/2017 05:19:08 م > ----------------------------------------------------------------------------------- INFO : 05/12/2017 05:19:08 م > To connect SM-G570F phone you have to perform the following steps: INFO : 05/12/2017 05:19:08 م > 1. Disconnect USB cable from phone. INFO : 05/12/2017 05:19:08 م > 2. Go to Menu->Settings->More->About Device. INFO : 05/12/2017 05:19:08 م > 3.Tap on "Build number" 7 times to enable developer options. INFO : 05/12/2017 05:19:08 م > 4. Go to Menu->Settings->More->Developer options. INFO : 05/12/2017 05:19:08 م > 5. Turn on "USB Debugging" option. INFO : 05/12/2017 05:19:14 م > ----------------------------------------------------------------------------------- INFO : 05/12/2017 05:19:14 م > Platform: Samsung Android INFO : 05/12/2017 05:19:14 م > Selected port: COM1 INFO : 05/12/2017 05:19:14 م > Selected model: SM-G570F INFO : 05/12/2017 05:19:14 م > Searching for UART interface.. INFO : 05/12/2017 05:19:14 م > COM80 WARN : 05/12/2017 05:19:14 م > Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds INFO : 05/12/2017 05:19:14 م > Searching for device. Please wait... INFO : 05/12/2017 05:20:43 م > Phone found. INFO : 05/12/2017 05:20:43 م > Rebooting phone in Upload Mode... INFO : 05/12/2017 05:20:44 م > OK WARN : 05/12/2017 05:21:00 م > Please connect phone to USB cable.. INFO : 05/12/2017 05:21:00 م > Searching for a phone. Please wait... INFO : 05/12/2017 05:21:05 م > OK INFO : 05/12/2017 05:21:05 م > Reading data... INFO : 05/12/2017 05:21:10 م > Checking operation... INFO : 05/12/2017 05:21:10 م > OK INFO : 05/12/2017 05:21:10 م > Searching for UART interface.. INFO : 05/12/2017 05:21:10 م > COM80 WARN : 05/12/2017 05:21:10 م > Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds INFO : 05/12/2017 05:21:10 م > Searching for device. Please wait... INFO : 05/12/2017 05:21:53 م > Phone found. INFO : 05/12/2017 05:21:53 م > Resetting FRP lock (1/4 attempt).. ERROR : 05/12/2017 05:22:59 م > unsuccessful INFO : 05/12/2017 05:22:59 م > Searching for UART interface.. INFO : 05/12/2017 05:22:59 م > COM80 WARN : 05/12/2017 05:22:59 م > Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds INFO : 05/12/2017 05:22:59 م > Searching for device. Please wait... INFO : 05/12/2017 05:23:12 م > Phone found. INFO : 05/12/2017 05:23:12 م > Resetting FRP lock (2/4 attempt).. SUCC : 05/12/2017 05:24:18 م > success WARN : 05/12/2017 05:24:18 م > FRP / Reactivation lock is successfully reseted! INFO : 05/12/2017 05:24:18 م > Performed by 2.6.2 Software version. Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\05-12-2017_17-16-18.log" closed (05/12/2017 05:26:55 م). |
The Following User Says Thank You to profkefah For This Useful Post: |
