02-22-2017, 01:31 | #1 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1083742 Status: Offline Sonork: 0022376011896 Thanks Meter: 4 | SM-G570F Reset FRP done ----------------------------------------------------------------------------------- To connect SM-G928T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-G570F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Operation was cancelled! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-G570F Searching for a phone (waiting for ADB device)... Operation was canceled Performed by 2.4.7 Software version. Please, select firmware file first! Please, select firmware file first! Selected AP file: H:\COMBINATION_OJV_FA60_G570FXXU1API2 _OJV1API2\COMBINATION_OJV_FA60_G570FXXU1API2_OJV1A PI2 \COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2_CL921 8515 _QB10877448_REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G570F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. Selected AP file: H:\COMBINATION_OJV_FA60_G570FXXU1API2 _OJV1API2\COMBINATION_OJV_FA60_G570FXXU1API2_OJV1A PI2 \COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2_CL921 8515 _QB10877448_REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G570F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. Selected AP file: H:\COMBINATION_OJV_FA60_G570FXXU1API2 _OJV1API2\COMBINATION_OJV_FA60_G570FXXU1API2_OJV1A PI2 \COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2_CL921 8515 _QB10877448_REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G570F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-G570F Searching for a phone (waiting for ADB device)... Reading info... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Resetting FRP lock.. Reset FRP cancelled! Operation was failed! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-G570F Searching for a phone (waiting for ADB device)... Reading info... Detected phone model: SM-G570F Firmware compiled date: Fri Oct 7 18:07:36 KST 2016 PDA version: G570FXXU1APJ2 CSC version: G570FOXE1APJ1 SW version: G570FXXU1APJ3 Phone SN: R28HB0Z5R7R Android version: 6.0.1 (MMB29K) Sales code: CAC Country: Central Asia HW platform: exynos5 HW Chip: exynos7570 HW Modem: SHANNON305 Security patch level: 2016-10-01 Codename: on5xeltejv Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-G570F Searching for a phone (waiting for ADB device)... Reading info... Detected phone model: SM-G570F Firmware compiled date: Fri Oct 7 18:07:36 KST 2016 PDA version: G570FXXU1APJ2 CSC version: G570FOXE1APJ1 SW version: G570FXXU1APJ3 Phone SN: R28HB0Z5R7R Android version: 6.0.1 (MMB29K) Sales code: CAC Country: Central Asia HW platform: exynos5 HW Chip: exynos7570 HW Modem: SHANNON305 Security patch level: 2016-10-01 Codename: on5xeltejv Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.4.7 Software version. Last edited by Octopus box; 02-22-2017 at 09:46. |
The Following 2 Users Say Thank You to kagnassy For This Useful Post: |
02-22-2017, 09:45 | #3 (permalink) | |
Freak Poster Join Date: Mar 2006
Member: 242574 Status: Offline Thanks Meter: 16 | Quote:
I too do so, but after loading the password is necessary. > Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-G570F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected AP file: D:\ALL\Samsung\SM-G570F\COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2\ COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2\COMBIN ATION_OJV_FA60_G570FXXU1API2_OJV1API2_CL9218515_QB 10877448_REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G570F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. Selected AP file: D:\ALL\Samsung\SM-G570F\COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2\ COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2\COMBIN ATION_OJV_FA60_G570FXXU1API2_OJV1API2_CL9218515_QB 10877448_REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G570F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. | |
02-22-2017, 11:52 | #4 (permalink) |
Member: 242574 Status: Offline Thanks Meter: 16 | |
The Following 2 Users Say Thank You to parabelum For This Useful Post: |
02-22-2017, 13:20 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To remove password request You can try to make Factory Reset from Recovery Mode. |
02-22-2017, 15:09 | #7 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | Quote: ----------------------------------------------------------------------------------- To connect SM-G570F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: rundll32.exe Selected firmware file: COMBINATION_OJV_FA60_G570FXXU1API2 _OJV1API2_CL9218515_QB10877448_REV00 _user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G570F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. Performed by 2.4.7 Software version. | |
The Following User Says Thank You to luyanda For This Useful Post: |
02-22-2017, 15:22 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You want to write firmware in *.tar format, You need to enable "Original Sam. firm. (*.tar)" option first. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
