01-17-2017, 13:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Unfortunately we don't have Combination firmware of SM-G600F at the moment. You can try to use Combination firmware of SM-G600FY, which is available in the Support Area. |
01-18-2017, 11:22 | #3 (permalink) |
Freak Poster Join Date: Mar 2005 Location: TURKEY Age: 42
Member: 127987 Status: Offline Thanks Meter: 6 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-G600F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G600FY phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Selected firmware file: combination_g600fy_g600fyxxu1apf1_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-G600FY into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing Firmware Failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G600FY Reset FRP/ Reactivation lock operation for SM-G600FY will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G600FY into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. FRP lock is successfully reseted! Wait 3-4 min then goto "Backup and reset" and make "Factory data reset" Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G600FY Proper android device not found. Make shure that "USB debug" option on the device is turned on. Rebooting phone failed. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM102 Selected model: SM-G600FY Proper android device not found. Make shure that "USB debug" option on the device is turned on. Rebooting phone failed. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM102 Selected model: SM-G600FY Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-G600FY into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Boot section... Boot section has been written successfully. Writing Firmware Failed Operation was failed! Performed by 2.4.7 Software version. Selected firmware file: combination_odd_fa51_g600fy_xxu1aoj2 _odd.oct Please put the phone into Download Mode and connect USB cable. To put SM-G600FY into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing Firmware Failed Performed by 2.4.7 Software version. I tried 2 G600Fy combination, but it did not please help |
01-18-2017, 11:32 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | According to Software log FRP lock was removed on first attempt: Quote:
01-18-2017, 11:49 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please do exactly the next: 1. Write "boot.img" partition of "combination_g600fy_g600fyxxu1apf1_boot.oct" firmware. 2. Perform "Reset FRP" operation. 3. Wait 3-4 min then goto "Backup and reset" and make "Factory data reset", after "Reset FRP" operation ends. |
01-18-2017, 12:05 | #7 (permalink) |
Member: 127987 Status: Offline Thanks Meter: 6 | Please put the phone into Download Mode and connect USB cable. To put SM-G600FY into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing Firmware Failed Performed by 2.4.7 Software version. |
01-18-2017, 12:16 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please reflash the phone with an original firmware, then try to write "boot.img" partition of "combination_g600fy_g600fyxxu1apf1_boot.oct" firmware again. |
01-19-2017, 14:01 | #9 (permalink) |
Member: 127987 Status: Offline Thanks Meter: 6 | I have installed the original software And then I applied what you said the result is the same Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-G600FY phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Selected firmware file: combination_g600fy_g600fyxxu1apf1_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-G600FY into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing Firmware Failed Performed by 2.4.7 Software version. |
01-19-2017, 14:30 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Most likely Combination firmware is not compatible with current firmware of the phone. You should try to find and use another Combination firmware. |
