04-07-2017, 12:32 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: India-punjab-TANDA
Member: 269808 Status: Offline Sonork: 100.1605553 Thanks Meter: 43 | Sm-g610f frp help COMBINATION_ODD_FA60_G610FDDU1API2_ODDFA60_G610FDD U1API2_CL9139094_QB10968271_REV00_user_mid_noship |
04-07-2017, 13:40 | #3 (permalink) | |
Member: 269808 Status: Offline Sonork: 100.1605553 Thanks Meter: 43 | Quote:
04-07-2017, 14:44 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,388 | After operation ends You need to enter phone Settings and make Factory Reset from there. If lock is still active and after the operation - You need to repeat the operation and carefully follow all Software prompts. |
04-08-2017, 00:51 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | How do g610f frp lock??? boot + boot img phone enable adb but phone sutck at start up logo??? help!!!!!!!!!!!!!!!!! |
The Following User Says Thank You to lihua For This Useful Post: |
04-08-2017, 06:38 | #6 (permalink) |
Member: 269808 Status: Offline Sonork: 100.1605553 Thanks Meter: 43 | After operation ends how to enter phone Settings. bcz phone does not shows main menu. phone stuck at samsung logo. |
The Following User Says Thank You to banwait For This Useful Post: |
04-08-2017, 11:37 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,388 | Quote:
There are few methods, of how to reset FPR on phones with latest firmware I. Try to write SBoot file of older firmware. Repeat "Reset FRP/Reactivation/EE" operation. II. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). Perform "Reset FRP" operation in Software. III. Write Full Combination Firmware. Go to "Developer Options" in phone Settings. Check "Enable OEM unlock" option. Make Factory Data Reset. Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! If neither of these methods helps, or necessary files are missing, You can use Factory Reset FRP Service. | |
