07-18-2018, 21:10 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: rep dom
Member: 2547059 Status: Offline Thanks Meter: 265 | SM-G610M Reset FRP successfully done by Octopus Box ----------------------------------------------------------------------------------- To connect SM-N910V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "##366633#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-N5100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N910V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "##366633#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-N5100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G610M Operation: Reset FRP - UART EMMC Searching for UART interface.. COM40 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation... This version of "sBoot" is not supported, try to downgrade "sBoot"! Operation was failed! Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G610M Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)... Please, press "OK" button on the phone to allow USB debugging. Reading info... Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SM-G610M Firmware compiled date: Thu Sep 28 01:59:09 KST 2017 PDA version: G610MUBU1BQI3 CSC version: G610MUWA1BQJ1 SW version: G610MUBU1BQI3 Phone SN: R58J31A6RVM Android version: 7.0 (NRD90M) Sales code: CDR Country: Dominican Republic HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2017-08-01 SIM 1 status: absent Codename: on7xelteub Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.6.9 Software version. Last edited by Octopus box; 07-19-2018 at 04:53. |
The Following 2 Users Say Thank You to sucre13 For This Useful Post: |
