04-26-2015, 15:56 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 778346 Status: Offline Thanks Meter: 34 | sm-g7102 flashing problem [Solved] ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: G7102XXUBNG4_G7102ODDBNG4 _INU_India_Android_4.4.2.oct Operation was canceled Please put the phone into Download Mode and connect USB cable. To put SM-G7102 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing Firmware Failed in download mode condition qualcomm securebott : enable (csb) secure mode enable, udc start(red color). set is in working condition i want to repair imei but i m getting error in flashing cf-root fie in odin. pls help me Last edited by Octopus box; 05-11-2015 at 16:38. |
04-27-2015, 16:06 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Reflash the phone with "SM-G7102_for_Unlock_and_Repair_IMEI_4.4.2" firmware from the Support Area, then try to root the phone with CF Auto Root again (make sure that You are using latest version of CF Auto Root). If problem will remain - try to use another root Software/Exploit. |
05-03-2015, 14:30 | #5 (permalink) | |
Member: 778346 Status: Offline Thanks Meter: 34 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.9.3 ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: SM-G7102_for_Unlock_and_Repair_IMEI_ 4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-G7102 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing Firmware Failed | |
