04-25-2018, 08:30 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2126418 Status: Offline Thanks Meter: 8 | SM-G7105 IMEI Repair question [Solved] I would like to fix imei for this phone the imei is blank After read info I dont have the choice to fix imei Welcome to Octoplus Box Samsung software version 2.6.7 ----------------------------------------------------------------------------------- To connect SM-G7105 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+MODEM+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090# or *#0808#" number. 12. Set "Diag config" to "DM/DUM over HSIC" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-G7105 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM56 Mode: Normal Phone model: SM-G7105 Firmware compiled date: Firmware compiled time: Firmware released date: -ω~ Firmware released time: SW version: Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM56 Selected model: SM-G7105 Mode: Normal Phone model: SM-G7105 Firmware compiled date: Firmware compiled time: Firmware released date: -ω~ Firmware released time: SW version: Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM56 Selected model: SM-G7105 Operation: Read security Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-G7105 Firmware compiled date: Fri Dec 19 20:38:51 KST 2014 PDA version: G7105XXUBNL1 CSC version: G7105EURBNL1 SW version: unknown Android version: 4.4.2 (KOT49H) Sales code: EUR Country: Greece HW platform: msm8226 HW Chip: MSM8926 HW Modem: unknown SIM 1 status: not ready Codename: ms01ltexx Checking Root: Phone is not Rooted. Reading security failed. Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM56 Selected model: SM-G7105 Operation: Read info Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-G7105 Firmware compiled date: Fri Dec 19 20:38:51 KST 2014 PDA version: G7105XXUBNL1 CSC version: G7105EURBNL1 SW version: unknown Android version: 4.4.2 (KOT49H) Sales code: EUR Country: Greece HW platform: msm8226 HW Chip: MSM8926 HW Modem: unknown SIM 1 status: not ready Codename: ms01ltexx Performed by 2.6.7 Software version. Last edited by Octopus box; 04-25-2018 at 09:45. |
04-25-2018, 08:47 | #2 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. As You can see from your Software log, modem part of your device is damaged: Quote:
04-25-2018, 09:34 | #5 (permalink) |
Member: 2126418 Status: Offline Thanks Meter: 8 | problem solved by flashing phone with full firmware Please put the phone into Download Mode and connect USB cable. To put SM-G7105 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing SBL1 section... SBL1 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.6.7 Software version. |
The Following User Says Thank You to petros047 For This Useful Post: |
