05-29-2015, 17:50 | #1 (permalink) |
No Life Poster Join Date: Mar 2013
Member: 1900730 Status: Offline Thanks Meter: 188 | SM-G7105L Unknown Baseband Fixed with Octopus! Code: Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\29-05-2015_01-05-35.log" created (29-05-2015 1:05:38). ERROR : 29-05-2015 1:05:38 > Access violation at address 0094A2B0 in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 29-05-2015 1:05:39 > Set up system language Spanish (file: Spanish.ini) INFO : 29-05-2015 1:05:39 > Welcome to Octoplus/Octopus Box Samsung software version 1.9.6 INFO : 29-05-2015 1:05:39 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:05:39 > To connect SM-G7105L phone you have to perform the following steps: INFO : 29-05-2015 1:05:39 > 1. Disconnect USB cable from phone. INFO : 29-05-2015 1:05:39 > 2. Go to Menu->Settings->More->About Device. INFO : 29-05-2015 1:05:39 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 29-05-2015 1:05:39 > 4. Go to Menu->Settings->More->Developer options. INFO : 29-05-2015 1:05:39 > 5. Turn on "USB Debugging" option. INFO : 29-05-2015 1:05:39 > 6. Go to dial window. INFO : 29-05-2015 1:05:39 > 7. Enter "*#0808#" number. INFO : 29-05-2015 1:05:39 > 8. Select "DM+MODEM+ADB". INFO : 29-05-2015 1:05:39 > 9. Press Home button. INFO : 29-05-2015 1:05:39 > 10. Go to dial window. INFO : 29-05-2015 1:05:39 > 11. Enter "*#9090#" number. INFO : 29-05-2015 1:05:39 > 12. Set "Diag config" to "DM/DUM over HSIC" value. INFO : 29-05-2015 1:05:39 > 13. Restart phone. INFO : 29-05-2015 1:05:39 > 14. Press "Read Info" in software. INFO : 29-05-2015 1:05:44 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:05:44 > To connect SM-G7105 phone you have to perform the following steps: INFO : 29-05-2015 1:05:44 > 1. Disconnect USB cable from phone. INFO : 29-05-2015 1:05:44 > 2. Go to Menu->Settings->More->About Device. INFO : 29-05-2015 1:05:44 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 29-05-2015 1:05:44 > 4. Go to Menu->Settings->More->Developer options. INFO : 29-05-2015 1:05:44 > 5. Turn on "USB Debugging" option. INFO : 29-05-2015 1:05:44 > 6. Go to dial window. INFO : 29-05-2015 1:05:44 > 7. Enter "*#0808#" number. INFO : 29-05-2015 1:05:44 > 8. Select "DM+MODEM+ADB". INFO : 29-05-2015 1:05:44 > 9. Press Home button. INFO : 29-05-2015 1:05:44 > 10. Go to dial window. INFO : 29-05-2015 1:05:44 > 11. Enter "*#9090#" number. INFO : 29-05-2015 1:05:44 > 12. Set "Diag config" to "DM/DUM over HSIC" value. INFO : 29-05-2015 1:05:44 > 13. Restart phone. INFO : 29-05-2015 1:05:44 > 14. Press "Read Info" in software. INFO : 29-05-2015 1:05:47 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:05:47 > To connect SM-G7102T phone you have to perform the following steps: INFO : 29-05-2015 1:05:47 > 1. Disconnect USB cable from phone. INFO : 29-05-2015 1:05:47 > 2. Go to Menu->Settings->More->About Device. INFO : 29-05-2015 1:05:47 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 29-05-2015 1:05:47 > 4. Go to Menu->Settings->More->Developer options. INFO : 29-05-2015 1:05:47 > 5. Turn on "USB Debugging" option. INFO : 29-05-2015 1:05:47 > 6. Go to dial window. INFO : 29-05-2015 1:05:47 > 7. Enter "*#0808#" number. INFO : 29-05-2015 1:05:47 > 8. Select "DM+Modem+ADB". INFO : 29-05-2015 1:05:47 > 9. Press Home button. INFO : 29-05-2015 1:05:47 > 10. Go to dial window. INFO : 29-05-2015 1:05:47 > 11. Enter "*#9090#" number. INFO : 29-05-2015 1:05:47 > 12. Set "Diag config" to "USB" value. INFO : 29-05-2015 1:05:47 > 13. Restart phone. INFO : 29-05-2015 1:05:47 > 14. Press "Read Info" in software. INFO : 29-05-2015 1:05:50 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:05:50 > To connect SM-G7102 phone you have to perform the following steps: INFO : 29-05-2015 1:05:50 > 1. Disconnect USB cable from phone. INFO : 29-05-2015 1:05:50 > 2. Go to Menu->Settings->More->About Device. INFO : 29-05-2015 1:05:50 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 29-05-2015 1:05:50 > 4. Go to Menu->Settings->More->Developer options. INFO : 29-05-2015 1:05:50 > 5. Turn on "USB Debugging" option. INFO : 29-05-2015 1:05:50 > 6. Go to dial window. INFO : 29-05-2015 1:05:50 > 7. Enter "*#0808#" number. INFO : 29-05-2015 1:05:50 > 8. Select "DM+Modem+ADB". INFO : 29-05-2015 1:05:50 > 9. Press Home button. INFO : 29-05-2015 1:05:50 > 10. Go to dial window. INFO : 29-05-2015 1:05:50 > 11. Enter "*#9090#" number. INFO : 29-05-2015 1:05:50 > 12. Set "Diag config" to "USB" value. INFO : 29-05-2015 1:05:50 > 13. Restart phone. INFO : 29-05-2015 1:05:50 > 14. Press "Read Info" in software. INFO : 29-05-2015 1:05:51 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:05:51 > To connect SM-G710 phone you have to perform the following steps: INFO : 29-05-2015 1:05:51 > 1. Disconnect USB cable from phone. INFO : 29-05-2015 1:05:51 > 2. Go to Menu->Settings->More->About Device. INFO : 29-05-2015 1:05:51 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 29-05-2015 1:05:51 > 4. Go to Menu->Settings->More->Developer options. INFO : 29-05-2015 1:05:51 > 5. Turn on "USB Debugging" option. INFO : 29-05-2015 1:05:51 > 6. Go to dial window. INFO : 29-05-2015 1:05:51 > 7. Enter "*#0808#" number. INFO : 29-05-2015 1:05:51 > 8. Select "DM+Modem+ADB". INFO : 29-05-2015 1:05:51 > 9. Press Home button. INFO : 29-05-2015 1:05:51 > 10. Go to dial window. INFO : 29-05-2015 1:05:51 > 11. Enter "*#9090#" number. INFO : 29-05-2015 1:05:51 > 12. Set "Diag config" to "USB" value. INFO : 29-05-2015 1:05:51 > 13. Restart phone. INFO : 29-05-2015 1:05:51 > 14. Press "Read Info" in software. INFO : 29-05-2015 1:05:56 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:05:56 > To connect SM-G900M phone you have to perform the following steps: INFO : 29-05-2015 1:05:56 > 1. Disconnect USB cable from phone. INFO : 29-05-2015 1:05:56 > 2. Go to Menu->Settings->More->About Device. INFO : 29-05-2015 1:05:56 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 29-05-2015 1:05:56 > 4. Go to Menu->Settings->More->Developer options. INFO : 29-05-2015 1:05:56 > 5. Turn on "USB Debugging" option. INFO : 29-05-2015 1:05:56 > 6. Go to dial window. INFO : 29-05-2015 1:05:56 > 7. Enter "*#0808#" number. INFO : 29-05-2015 1:05:56 > 8. Select "DM+Modem+ADB". INFO : 29-05-2015 1:05:56 > 9. Press Home button. INFO : 29-05-2015 1:05:56 > 10. Go to dial window. INFO : 29-05-2015 1:05:56 > 11. Enter "*#9090#" number. INFO : 29-05-2015 1:05:56 > 12. Set "Diag config" to "USB" value. INFO : 29-05-2015 1:05:56 > 13. Restart phone. INFO : 29-05-2015 1:05:56 > 14. Press "Read Info" in software. INFO : 29-05-2015 1:05:57 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:05:57 > Platform: Samsung Android INFO : 29-05-2015 1:05:57 > Selected port: COM1 INFO : 29-05-2015 1:05:57 > Selected model: SM-G900M WARN : 29-05-2015 1:05:57 > To put SM-G900M into Download Mode, You have to perform the following steps: WARN : 29-05-2015 1:05:57 > 1. Reconnect the battery. WARN : 29-05-2015 1:05:57 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 29-05-2015 1:05:57 > 3. When phone turns on, press "Volume+" key. INFO : 29-05-2015 1:05:58 > Searching for a phone. Please wait... INFO : 29-05-2015 1:05:58 > Phone found. INFO : 29-05-2015 1:05:58 > Repairing EFS... INFO : 29-05-2015 1:06:00 > EFS Repair successfully INFO : 29-05-2015 1:06:22 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:06:22 > To connect SM-G7105 phone you have to perform the following steps: INFO : 29-05-2015 1:06:22 > 1. Disconnect USB cable from phone. INFO : 29-05-2015 1:06:22 > 2. Go to Menu->Settings->More->About Device. INFO : 29-05-2015 1:06:22 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 29-05-2015 1:06:22 > 4. Go to Menu->Settings->More->Developer options. INFO : 29-05-2015 1:06:22 > 5. Turn on "USB Debugging" option. INFO : 29-05-2015 1:06:22 > 6. Go to dial window. INFO : 29-05-2015 1:06:22 > 7. Enter "*#0808#" number. INFO : 29-05-2015 1:06:22 > 8. Select "DM+MODEM+ADB". INFO : 29-05-2015 1:06:22 > 9. Press Home button. INFO : 29-05-2015 1:06:22 > 10. Go to dial window. INFO : 29-05-2015 1:06:22 > 11. Enter "*#9090#" number. INFO : 29-05-2015 1:06:22 > 12. Set "Diag config" to "DM/DUM over HSIC" value. INFO : 29-05-2015 1:06:22 > 13. Restart phone. INFO : 29-05-2015 1:06:22 > 14. Press "Read Info" in software. INFO : 29-05-2015 1:06:24 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:06:24 > To connect SM-G7105L phone you have to perform the following steps: INFO : 29-05-2015 1:06:24 > 1. Disconnect USB cable from phone. INFO : 29-05-2015 1:06:24 > 2. Go to Menu->Settings->More->About Device. INFO : 29-05-2015 1:06:24 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 29-05-2015 1:06:24 > 4. Go to Menu->Settings->More->Developer options. INFO : 29-05-2015 1:06:24 > 5. Turn on "USB Debugging" option. INFO : 29-05-2015 1:06:24 > 6. Go to dial window. INFO : 29-05-2015 1:06:24 > 7. Enter "*#0808#" number. INFO : 29-05-2015 1:06:24 > 8. Select "DM+MODEM+ADB". INFO : 29-05-2015 1:06:24 > 9. Press Home button. INFO : 29-05-2015 1:06:24 > 10. Go to dial window. INFO : 29-05-2015 1:06:24 > 11. Enter "*#9090#" number. INFO : 29-05-2015 1:06:24 > 12. Set "Diag config" to "DM/DUM over HSIC" value. INFO : 29-05-2015 1:06:24 > 13. Restart phone. INFO : 29-05-2015 1:06:24 > 14. Press "Read Info" in software. INFO : 29-05-2015 1:06:33 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:06:33 > Platform: Samsung Android INFO : 29-05-2015 1:06:33 > Selected port: COM1 INFO : 29-05-2015 1:06:33 > Selected model: SM-G7105L ERROR : 29-05-2015 1:06:35 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. ERROR : 29-05-2015 1:06:35 > Writing security failed. INFO : 29-05-2015 1:06:55 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:06:55 > Platform: Samsung Android INFO : 29-05-2015 1:06:55 > Selected port: COM1 INFO : 29-05-2015 1:06:55 > Selected model: SM-G7105L INFO : 29-05-2015 1:06:55 > Reading info, please wait... ERROR : 29-05-2015 1:06:55 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. INFO : 29-05-2015 1:06:57 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:06:57 > Platform: Samsung Android INFO : 29-05-2015 1:06:57 > Selected port: COM32 INFO : 29-05-2015 1:06:57 > Selected model: SM-G7105L INFO : 29-05-2015 1:06:57 > Reading info, please wait... ERROR : 29-05-2015 1:06:57 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. INFO : 29-05-2015 1:06:59 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:06:59 > Platform: Samsung Android INFO : 29-05-2015 1:06:59 > Selected port: COM32 INFO : 29-05-2015 1:06:59 > Selected model: SM-G7105L INFO : 29-05-2015 1:06:59 > Mode: Normal INFO : 29-05-2015 1:06:59 > Phone model: SM-G7105L INFO : 29-05-2015 1:06:59 > Firmware compiled date: Aug 28 2014 INFO : 29-05-2015 1:06:59 > Firmware compiled time: 03:00:00 INFO : 29-05-2015 1:06:59 > Firmware released date: Apr 6 2015 INFO : 29-05-2015 1:06:59 > Firmware released time: 23:18:26 WARN : 29-05-2015 1:06:59 > Incorrect IMEI INFO : 29-05-2015 1:06:59 > SW version: MPSS.DI.2.0.c8-00079-M8926DAAAANAZM-1.01685860.4843.1 INFO : 29-05-2015 1:07:06 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:07:06 > Platform: Samsung Android INFO : 29-05-2015 1:07:06 > Selected port: COM32 INFO : 29-05-2015 1:07:06 > Selected model: SM-G7105L INFO : 29-05-2015 1:07:10 > Selected file: C:\Users\Administrador\Desktop\cert-sm-g7105l_352695060049906.cert ERROR : 29-05-2015 1:07:10 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. INFO : 29-05-2015 1:07:10 > Certificate has been written successfully INFO : 29-05-2015 1:07:10 > Please, restart the phone to apply changes INFO : 29-05-2015 1:07:15 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:07:15 > Platform: Samsung Android INFO : 29-05-2015 1:07:15 > Selected port: COM32 INFO : 29-05-2015 1:07:15 > Selected model: SM-G7105L INFO : 29-05-2015 1:07:15 > Mode: Normal INFO : 29-05-2015 1:07:15 > Phone model: SM-G7105L INFO : 29-05-2015 1:07:15 > Firmware compiled date: Aug 28 2014 INFO : 29-05-2015 1:07:15 > Firmware compiled time: 03:00:00 INFO : 29-05-2015 1:07:15 > Firmware released date: Apr 6 2015 INFO : 29-05-2015 1:07:15 > Firmware released time: 23:18:26 WARN : 29-05-2015 1:07:15 > Incorrect IMEI INFO : 29-05-2015 1:07:15 > SW version: MPSS.DI.2.0.c8-00079-M8926DAAAANAZM-1.01685860.4843.1 INFO : 29-05-2015 1:07:17 > ----------------------------------------------------------------------------------- INFO : 29-05-2015 1:07:18 > Platform: Samsung Android INFO : 29-05-2015 1:07:18 > Selected port: COM32 INFO : 29-05-2015 1:07:18 > Selected model: SM-G7105L INFO : 29-05-2015 1:07:18 > Reading info... INFO : 29-05-2015 1:07:18 > Mode: Normal INFO : 29-05-2015 1:07:18 > Firmware compiled date: Aug 28 2014 INFO : 29-05-2015 1:07:18 > Firmware compiled time: 03:00:00 INFO : 29-05-2015 1:07:18 > Firmware released date: Apr 6 2015 INFO : 29-05-2015 1:07:18 > Firmware released time: 23:18:26 INFO : 29-05-2015 1:07:18 > SW Version: MPSS.DI.2.0.c8-00079-M8926DAAAANAZM-1.01685860.4843.1 ERROR : 29-05-2015 1:07:18 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. INFO : 29-05-2015 1:07:18 > Unlocking phone... WARN : 29-05-2015 1:07:18 > Phone will restart now. Please don't disconnect cable! INFO : 29-05-2015 1:07:18 > Phone is successfully unlocked WARN : 29-05-2015 1:07:18 > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\29-05-2015_01-05-35.log" closed (29-05-2015 1:07:51). |
