08-11-2015, 13:12 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: UK
Member: 1779384 Status: Offline Thanks Meter: 13 | sm-g800f write cert problem battery pin is covered with a bit of tape but still just does the same thing. theres no thinking about it it just goes straight to failed. logs below. any help would be really appreciated thank. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-G800F Reading info, please wait... Detected phone model: SM-G800F Firmware compiled date: Fri Oct 10 11:45:33 KST 2014 PDA version: G800FXXU1ANJ2 CSC version: G800FBTU1ANJ1 SW version: G800FXXU1ANJ2 Phone IMEI: 350695200123951 Phone SN: R58F80PLQCN Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-G800F Selected file: C:\Users\clive\Downloads\Cert-SM-G800F_ 352960061522321_RF8F70JJEPH.cert Detected phone model: SM-G800F Firmware compiled date: Fri Oct 10 11:45:33 KST 2014 PDA version: G800FXXU1ANJ2 CSC version: G800FBTU1ANJ1 SW version: G800FXXU1ANJ2 Phone IMEI: 350695200123951 Phone SN: R58F80PLQCN Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G800F-Unknown11-08-2015_13-05-01-.asec file Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed |
08-11-2015, 13:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please install latest Software version, reinstall FTDI drivers and restart PC. Repeat "Write Cert" operation after PC restart. Try to use different Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. Try to use another box as UART interface. |
08-11-2015, 16:20 | #3 (permalink) |
Member: 1779384 Status: Offline Thanks Meter: 13 | nope nothing is working. software just straight away gives up without even looking for my phone on uart. ive check the resister that is fine. i wrote a cert file on a note 4 the other night all with the same equipment and everything was fine. its puzzling to say the least |
08-11-2015, 16:41 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please upload *.log and *.logx files of "Write Cert" operation, from "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder and post here download link. We will check where can be the problem. |
08-11-2015, 21:26 | #5 (permalink) |
Member: 1779384 Status: Offline Thanks Meter: 13 | https://www.dropbox.com/s/t9zaly1316...6-18.logx?dl=0 https://www.dropbox.com/s/9fd3rq9l5y...56-18.log?dl=0 both logs as requested. the phone is going back to a nokia imei as seen on other posts with this issue. i am using the security back up to put this imei back to is original one but still can not write the cert ? |
08-12-2015, 08:50 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please reflash the phone with any Android 4.4.2 firmware from the Support Area and repeat "Write Cert" operation. Post here results and full Software log of performed operations. |
08-12-2015, 11:32 | #7 (permalink) |
Member: 1779384 Status: Offline Thanks Meter: 13 | some how the imei number has actually changed. all i did was flashed an efs file i found on this forum and the imei number had changed and so far seems to be valid in my country. so for now im not going to play about with the phone anymore lol. should this one get disconnected i shall come back here and try again. (posting what i did here just in case i get another one and will find this thread to remind me what worked for this phone lol) |
08-12-2015, 19:39 | #8 (permalink) |
Member: 1779384 Status: Offline Thanks Meter: 13 | update, i would nly get a very weak bad signal the way it was b4, so i tried to write cert again and still the samething happens. ive reflashed the phone with a rom from support, that hasnt made a bit of diiferance either. i am completely stumped as to why i can not write cert to this phone. Welcome to Octoplus/Octopus Box Samsung software version 2.0.3 ----------------------------------------------------------------------------------- To connect SM-G800F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G800F Selected file: C:\Users\clive\Downloads\cert-sm-g800y_ 354481065051157_r58f91kvvk.cert Detected phone model: SM-G800F Firmware compiled date: Fri Oct 10 11:45:33 KST 2014 PDA version: G800FXXU1ANJ2 CSC version: G800FPHE1ANK1 SW version: G800FXXU1ANJ2 Phone IMEI: 350695200123951 Phone SN: RF8F705A3BD Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G800F-Unknown12-08-2015_19-33-31-.asec file Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed |
08-13-2015, 08:28 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please upload *.log and *.logx files of "Write Cert" operation, which You tried to perform, after phone has been reflashed. Post here download link, we will check where can be the problem. |
08-13-2015, 14:09 | #10 (permalink) |
Member: 1779384 Status: Offline Thanks Meter: 13 | hi, right ive sorted the not attempting to write cert file. octopus does now finally go to write the cert, most of them on the support site fail though, but 2 of them do write successfully but dont work in the uk lol i guess its just a case of trying to locate a good cert file for the uk now but thanks for your help, i really appreciate it |
08-13-2015, 18:41 | #11 (permalink) |
Member: 1779384 Status: Offline Thanks Meter: 13 | great, i fix 1 problem, now confronted with another. after trying several cert files i could lay my hands all most will work and i can make and receive calls, but the phone only get a very week 1 bar signal no matter where i take the phone, i have tried different sim cards from different operators but still the same. the phone is mint and never had any damage so i dont see the need to open it up. so i figure it must be a software issue? has anyone got any ideas lol? |
08-14-2015, 09:07 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please make a Factory Reset and reflash the phone, then check, whether phone receives signal normally. Last edited by Octopus box; 08-14-2015 at 09:14. |
