04-01-2015, 17:57 | #2 (permalink) |
Freak Poster Join Date: Nov 2011 Location: GSMHOSTING
Member: 1691378 Status: Offline Sonork: 100.1645448 Thanks Meter: 141 | G900f unlock unlock via cert method BUT MAY NOT WORK ON 5.0 ...... GIVE A TRY......BACKUP ALL DATA ....IF IT DOSENT WORK ATLEST YOU CAN GO TO INITIAL CONDITION 1) root 2) bacup data (efs nvm qcn and cert and keep it safe) 3) wipe securty 4) write cert 5) write qcn note - backup qcn, efs, nvm, security, and certs before proceding with unlock regards acgsm |
04-01-2015, 18:29 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Downgrade the phone to 4.4.2 and do the next: 1. Root the phone. 2. Perform "Wipe Security". 3. Perform "Write Cert". Also, You can try to do the next: 1. Check whether "Enable cp logging" option available in Recovery Mode and activate it. If option is not available - reflash the phone with Android 5.0 firmware from the Support Area. 2. Wipe phone's Security as it is described in this video: https://www.youtube.com/watch?v=1DtPT2MmNhg 3. Perform "Write Cert" operation. |
04-01-2015, 18:35 | #4 (permalink) |
Banned Join Date: Mar 2015
Member: 2371548 Status: Offline Thanks Meter: 27 | Has octopus team figured out how to write cert via USB on 5.0 phones yet since now we can enable dm mode? Every 5.0 phone I try to write cert to via USB it just reads some of the phones info and just stops working. |
04-01-2015, 18:47 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Currently it is not possible to write Cert file via USB, because it requires root. Current root solutions using old Recovery, which don't have option, that enables Diagnostic port. |
04-01-2015, 19:16 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Yes, it is possible to downgrade SM-G900F from Android 5.0 to Android 4.4.2. |
04-01-2015, 19:30 | #8 (permalink) |
Member: 2371548 Status: Offline Thanks Meter: 27 | After you root the phone with cf auto you just flash the 5.0 recovery back then enable dm mode. so now its still on 5.0 rooted and dm mode enabled. the problem is not root or dm mode. the problem is writing the cert via usb. |
04-01-2015, 20:28 | #9 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | It will be easy for product supporter and for us too who want to help you if you post logs and screen shot too.. as it will provide a clear picture... |
04-01-2015, 20:58 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Currently there is no stable solution for phones on Android 5.x . When we will find a solution it will be added. |
04-01-2015, 21:16 | #12 (permalink) |
Member: 2371548 Status: Offline Thanks Meter: 27 | Do you think it has to do something with the AT. Because there is no issue wiping the efs with octopus just a problem writing cert. And I know octopus is wiping the efs correctly because i can write the cert via UART with no issues after wiping efs with octopus. And thanks for cleaning up the garbage. |
04-02-2015, 05:58 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | @ dominica What do You mean under "phone did not work"? What is the problem exactly? Also, please post here full Software log with Write Firmware procedure and with all of your other actions. |
