02-28-2016, 09:57 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Sylhet Bangladesh
Member: 2145140 Status: Offline Sonork: 100.1650938 Thanks Meter: 90 | SM-G900F Phone is successfully unlocked ----------------------------------------------------------------------------------- To connect GT-B5510 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-A887 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Type *#782872#. 3. Press confirm button. 4. Type *#7465625# and leave appeared message on phone screen. 5. Connect USB cable and select Diagnostics COM port. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-B5510 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-A887 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Type *#782872#. 3. Press confirm button. 4. Type *#7465625# and leave appeared message on phone screen. 5. Connect USB cable and select Diagnostics COM port. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-B5510 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-A887 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Type *#782872#. 3. Press confirm button. 4. Type *#7465625# and leave appeared message on phone screen. 5. Connect USB cable and select Diagnostics COM port. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G900F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM45 Mode: Normal Phone model: SM-G900F Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: May 8 2014 Firmware released time: 10:38:24 Phone IMEI: 353687-06-071366-3 SW version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: SM-G900F Reading info... Mode: Normal Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: May 8 2014 Firmware released time: 10:38:24 SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Thu May 8 12:44:41 KST 2014 PDA version: G900FXXU1ANE2 CSC version: G900FEVR1ANF1 SW version: G900FXXU1ANE2 Phone IMEI: 353687060713663 Phone SN: RF8F41H0AWY Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. |
The Following 2 Users Say Thank You to Anamul.2014 For This Useful Post: |
