01-15-2016, 13:33 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: pakistan
Member: 319303 Status: Offline Thanks Meter: 22 | sm-g900p data not working Code: Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 Selected firmware file: g900pvpu3bog1_g900pspt3bog1_spr_android_ 5.0.oct Please put the phone into Download Mode and connect USB cable. To put SM-G900P into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. |
01-15-2016, 16:29 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please make backup of phone's Security and QCN ("Read Security" and "Read QCN" respectively), then try to write QCN file from the Support Area. |
01-15-2016, 18:04 | #7 (permalink) |
Member: 319303 Status: Offline Thanks Meter: 22 | Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-G900P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#3424#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM82 Selected model: SM-G900P Reading info... Mode: Normal Firmware compiled date: Aug 05 2014 Firmware compiled time: G900P.04 Firmware released date: Jul 30 2015 Firmware released time: 14:48:13 SW Version: MPSS.DI.2.0.1.c2-00082-M8974AAAAANRZM-1 Reading QCN... Send SPC... Failed! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM82 Selected model: SM-G900P Reading info... Phone was not found on the selected port! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM82 Selected model: SM-G900P Reading info... Phone was not found on the selected port! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM82 Selected model: SM-G900P Reading info... Mode: Normal Firmware compiled date: Aug 05 2014 Firmware compiled time: G900P.04 Firmware released date: Jul 30 2015 Firmware released time: 14:48:13 SW Version: MPSS.DI.2.0.1.c2-00082-M8974AAAAANRZM-1 Reading QCN... Send SPC... Failed! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM82 Selected model: SM-G900P Reading info, please wait... Detected phone model: SM-G900P Firmware compiled date: Thu Jul 30 15:39:53 KST 2015 PDA version: G900PVPU3BOG1 CSC version: G900PSPT3BOG1 SW version: G900PVPU3BOG1 Phone SN: 00000000000 Android version: 5.0 (LRX21T) |
01-15-2016, 18:27 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please remove SD and SIM cards from the phone and repeat "Read QCN" operation. If problem will persist - upload *.log and *.logx of performed operations to any file-sharing service and post here download link. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
