06-13-2015, 20:29 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Brazil
Member: 232960 Status: Offline Thanks Meter: 419 | SM G900p sprint 5.0 unlock problem Octoplus says "unlocked sucessifull" but still "invalid sim card" shows on phone. HELP Bemvindo na Octoplus/Octopus Box Samsung software versão 1.9.6 ----------------------------------------------------------------------------------- To connect SM-G900P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#3424#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM1 Modelo seleccionado: SM-G900P Reading info... Mode: Normal Firmware compiled date: Aug 05 2014 Firmware compiled time: G900P.04 Firmware released date: Jan 23 2015 Firmware released time: 11:27:45 SW Version: MPSS.DI.2.0.1.c2-00082-M8974AAAAANRZM-1 Modelo do telefone detectado: SM-G900P Data de criação do firmware: Fri Jan 23 12:10:50 KST 2015 PDA version: G900PVPU1BOA6 CSC version: G900PSPT1BOA6 Versão do SW: G900PVPU1BOA6 IMEI do telefone: Unknown Phone SN: 00000000000 Android version: 5.0 (LRX21T) Reading security backup, please wait... Backup saved as Security-SM-G900P-Unknown-13-06-2015_16-19-18 file Liberando o telefone... Phone will restart now. Please don't disconnect cable! O telefone foi liberado com êxito To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
The Following User Says Thank You to edcentec For This Useful Post: |
06-22-2015, 18:38 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | I have Same problem, already try to downgrade with this tutorial [LINK][ROM][ODIN][TAR]SM-G900P NE5 (NE5 Mode… | Sprint Samsung Galaxy S 5 | XDA Forums Rwilco12's Android Repository - Downloads but show error flashing. |
06-24-2015, 18:03 | #6 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Quote:
<ID:0/042> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> ALL_SPT_G900PVPU1ANE5_G900PSPT1ANE5_1750661_REV00_ user_low_ship_MULTI_CERT.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/042> Odin v.3 engine (ID:42).. <ID:0/042> File analysis.. <ID:0/042> SetupConnection.. <ID:0/042> Initialzation.. <ID:0/042> Set PIT file.. <ID:0/042> DO NOT TURN OFF TARGET!! <ID:0/042> Get PIT for mapping.. <ID:0/042> Firmware update start.. <ID:0/042> aboot.mbn <ID:0/042> NAND Write Start!! <ID:0/042> FAIL! (Auth) <OSM> All threads completed. (succeed 0 / failed 1) | |
06-24-2015, 19:06 | #7 (permalink) | |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Quote:
The Following User Says Thank You to F_X For This Useful Post: |
06-25-2015, 11:15 | #10 (permalink) | |
file i am using this Rwilco12's Android Repository - Downloads u have any other file tested file ? | |
06-25-2015, 18:11 | #11 (permalink) | |
Member: 2273678 Status: Offline Thanks Meter: 293 | Quote: | |
06-25-2015, 18:58 | #12 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | I don't think it's locked necessarily... It probably just has rollback protection in place since 5.1.1 includes Device Protection. CF writes to recovery and cache partitions, so that should still be doable. CF hasn't been updated to include recovery and cache imgs from the new update, so in essence it's like trying to roll back, hence why it's causing bootloops. |
06-25-2015, 19:30 | #13 (permalink) | |
06-25-2015, 20:40 | #14 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | I think the term you guys are looking for here is "secured bootloader". Secured bootloaders keep the phone on a current or newer revision of the firmware. It stops the download process if a older revision of a firmware is sent to the phone. Locked bootloaders are only on ATT and Verizon phones as far as i know. On these phones you cannot load a custom recovery through download mode whereas on Sprint and T mobile you can (which dont have locked bootloaders). |
The Following 3 Users Say Thank You to ecs87 For This Useful Post: |
06-25-2015, 22:00 | #15 (permalink) | |
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
