03-03-2015, 04:24 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | sm-g900s after wipe phone show imei 00000 can not wirte g900f cert? always error g900s will work with g900f cert? i need to g900s qcn and cert plz |
03-03-2015, 23:19 | #4 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
Code: Welcome to Octoplus/Octopus Box Samsung software version 1.8.4 ----------------------------------------------------------------------------------- To connect SM-G900S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900S ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900S Firmware compiled date: Sat Mar 22 22:54:44 KST 2014 PDA version: G900SKSU1ANCE CSC version: G900SSKC1ANCE SW version: G900SKSU1ANCD Phone IMEI: 000000000000000 Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Mar 06 2014 Firmware compiled time: 15:00:00 Firmware released date: Mar 21 2014 Firmware released time: 12:57:22 SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G900S-000000000000000-04-03-2015_11-11- 01-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G900S-000000000000000-04-03-2015_11-14- 35-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Mar 06 2014 Firmware compiled time: 15:00:00 Firmware released date: Mar 21 2014 Firmware released time: 12:57:22 SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900S Selected file: C:\Users\salim\Desktop\cert\g900f\g900f\Cert-SM-G900F_ 352558067456393_00000000000.cert Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SM-G900S Firmware compiled date: Sat Mar 22 22:54:44 KST 2014 PDA version: G900SKSU1ANCE CSC version: G900SSKC1ANCE SW version: G900SKSU1ANCD Phone IMEI: 000000000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed | |
03-04-2015, 07:49 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Do the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Install the latest Software version (Software). 3. Take out SIM and SD cards from the device. 4. Run the Software. 5. Re-flash the phone with another firmware. 6. Make Wipe Security. 7. Make Write Cert again. 8. Close the Software. 9. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the links, we will research, where can be the problem with your device. |
03-05-2015, 02:03 | #6 (permalink) | |
05-03-2015_13-36-28 05-03-2015_13-36-28 i m having problem wiping efs every time i do that it saying this Code: Welcome to Octoplus/Octopus Box Samsung software version 1.8.6 ----------------------------------------------------------------------------------- To connect SM-G900S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900S ADB server killed. Detected phone model: SM-G900S Firmware compiled date: Wed May 14 19:42:14 KST 2014 PDA version: G900SKSU1ANE5 CSC version: G900SSKC1ANE5 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading info... Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900S ADB server killed. Detected phone model: SM-G900S Firmware compiled date: Wed May 14 19:42:14 KST 2014 PDA version: G900SKSU1ANE5 CSC version: G900SSKC1ANE5 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading info... Phone was not found on the selected port! so what is saying this? | |
03-05-2015, 03:22 | #7 (permalink) | |
Desktop i hope u can solve my problem i think i need good g900s qcn cert | |
03-05-2015, 07:39 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). | |
03-06-2015, 00:46 | #9 (permalink) | |
can i get qcn and cert for this phone g900s? | |
03-06-2015, 08:09 | #11 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ MUTUAL Quote:
@ zintung2911 Quote:
1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Install the latest Software version (Software). 3. Take out SIM and SD cards from the device. 4. Run the Software. 5. Re-flash the phone with another firmware. 6. Make Wipe Security. 7. Make Write Cert again. 8. Close the Software. 9. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the links, we will research, where can be the problem with your device. | ||
