04-06-2015, 10:13 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Octoplus Team
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | SM-G900S need cert file I need cert file SM-G900S Two hour ago I succesfully repaired Repair security / wipe security. Do next step write cert file i have not this file. Please share it. Code: Вас приветствует Octoplus/Octopus Box Samsung software версии 1.7.8 ----------------------------------------------------------------------------------- To connect SGH-I747 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "UART" to "PDA" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I747 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "UART" to "PDA" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G900S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Платформа: Samsung Android Выбранный порт: COM1 Выбранная модель: SM-G900S Определена модель телефона: SM-G900S Дата создания прошивки: Wed May 14 19:42:14 KST 2014 PDA version: G900SKSU1ANE5 CSC version: G900SSKC1ANE5 Версия программного обеспечения: G900SKSU1AND8 IMEI телефона: 000000000000000 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Mar 06 2014 Firmware compiled time: 15:00:00 Firmware released date: Apr 22 2014 Firmware released time: 18:13:05 SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\QCN-SM-G900S-000000000000000-06-04-2015_12-14-33-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G900S-000000000000000-06-04-2015_12-18-13-.asec file Wiping EFS... EFS wipe successfully Сейчас телефон будет перезагружен Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Mar 06 2014 Firmware compiled time: 15:00:00 Firmware released date: Apr 22 2014 Firmware released time: 18:13:05 SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Сейчас телефон будет перезагружен ----------------------------------------------------------------------------------- Платформа: Samsung Android Выбранный порт: COM1 Выбранная модель: SM-G900S Операция отменена Writing Certificate failed ----------------------------------------------------------------------------------- Платформа: Samsung Android Выбранный порт: COM1 Выбранная модель: SM-G900S Selected file must be *.cert Writing Certificate failed I use this file: SM-G900H_353285066458472_RF1F42NXP9.cert Cert-SM-G900H-353285066458472-RF1F42NXP9V.cert |
The Following User Says Thank You to Islombek1991 For This Useful Post: |
04-06-2015, 10:18 | #2 (permalink) |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | I searched this link but didnt fint it. http://forum.gsmhosting.com/vbb/f684...0/index18.html |
04-06-2015, 11:30 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi, this variant of S5 (G900S) is Korean and is Qualcomm Cpu. CRT of G900H isn't compatible with this variant. Try to Wipe Security/Efs Right, i not see that after Wipe you have resetted Mei to Unknown/00000000..... Try with this procedure: Connect the phone to PC and configure it: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in the "Main" tab in the Software. When phone's info will be read out from the "Main" tab in the Software, do the next: 5. Make "Wipe Security". Check phone's IMEI after wiping, if IMEI is still present - this means, Security was not wiped successfully. Try to wipe Security/EFS via phone's menu. To wipe Security/EFS from the phone's menu, do the next: 1. Write any firmware (at you risk for this variant)>>>>>> (don't root the phone after, this is important!). 2. Type *#9090#. 3. Type at rigth corner MENU + select "Back". 4. Typy at rigth corner MENU + input Q. 5. Type at rigth croner MENU + input 0000. https://www.youtube.com/watch?v=1DtPT2MmNhg. 6. Write Crt BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
04-06-2015, 11:48 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | @ Islombek1991 Hello. 1. Install and use the latest Software version (Software). 2. Quote:
04-06-2015, 11:50 | #5 (permalink) | ||
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | You are right brother. I use this instruction but imei still 00000000 Quote:
04-06-2015, 12:02 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Of course, as You can see from your Software log, IMEI Certificate was not written successfully: Quote:
1. Close the Software. 2. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 3. Install the latest Software version (Software). 4. Take out SIM and SD cards from the device. 5. Run the Software. 6. Re-start the phone. 7. Re-flash the phone. 8. Make Factory data reset and wipe cache partition. 9. Root the phone. 10. Try to write IMEI Certificate again. 11. Close the Software. 12. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the links, we will research, where can be the problem with your device and say You the result. | |
04-07-2015, 04:52 | #7 (permalink) | |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | Quote:
Thanks answer me. I have a question. If I do your instruction after 10 step where can I downlaod Certificate file? Code: 10. Try to write IMEI Certificate again. When i repair imei box ask me step 3.Write Certificate ("Write Cert" button) | |
04-07-2015, 06:31 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | All Certificates files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/Certificates/". |
04-18-2015, 13:28 | #10 (permalink) |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | Hello bro How are you? 1. I write the firmware G900SKSU1BOA1_G900SSKC1BOA1_SKC.zip 2. Rooted is the phone 3. Wipe securite cant write. 4. I upload LOGs Zippyshare.com - LOG.rar Please any solution. I am wating your answer. |
04-18-2015, 13:43 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Your phone has 5.0 firmware. You need to downgrade firmware to 4.4.x. Currently no stable solution for phones on Android 5.x |
