07-27-2017, 19:38 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: the boss of samsung
Member: 2558211 Status: Offline Thanks Meter: 90 | SM-G900T successfully unlocked ----------------------------------------------------------------------------------- To connect SM-G935U phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: SM-G900T Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM112 Mode: Normal Phone model: SM-G900T Firmware compiled date: Apr 16 2015 Firmware compiled time: 19:00:00 Firmware released date: Dec 9 2015 Firmware released time: 18:56:21 Phone IMEI: 351881-06-289838-0 SW version: MPSS.DI.2.0.1.c2-00158-M8974AAAAANRZM-1 Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM112 Selected model: SM-G900T Reading info... Mode: Normal Firmware compiled date: Apr 16 2015 Firmware compiled time: 19:00:00 Firmware released date: Dec 9 2015 Firmware released time: 18:56:21 SW Version: MPSS.DI.2.0.1.c2-00158-M8974AAAAANRZM-1 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.5.6 Software version. Last edited by Octopus box; 07-27-2017 at 20:58. |
