04-08-2015, 19:21 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1870650 Status: Offline Thanks Meter: 12 | SM-G900V fail to wipe security and write qcn & Cert I tried to write qcn but can't here's log...if you have any idea let me know...Thanks Welcome to Octoplus/Octopus Box Samsung software version 1.8.5 ----------------------------------------------------------------------------------- To connect SM-G900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM65 Selected model: SM-G900A Reading info, please wait... Detected phone model: SM-G900V Firmware compiled date: Mon Nov 17 19:33:49 KST 2014 PDA version: G900VVRU1ANK2 CSC version: G900VVZW1ANK2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM65 Selected model: SM-G900A Detected phone model: SM-G900V Firmware compiled date: Mon Nov 17 19:33:49 KST 2014 PDA version: Unknown CSC version: G900VVRU1ANK2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.4 (KTU84P) Reading info... Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM65 Selected model: SM-G900A Reading info... Phone was not found on the selected port! Writing QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM65 Selected model: SM-G900A Reading info, please wait... Detected phone model: SM-G900V Firmware compiled date: Mon Nov 17 19:33:49 KST 2014 PDA version: G900VVRU1ANK2 CSC version: G900VVZW1ANK2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.4 (KTU84P) |
04-08-2015, 19:36 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Mr. Maurioski is right. As You can see from your Software log, phone's modem part is damaged: Quote:
You should reflash the device with different firmwares and check, whether modem is correct (not Unknown). It is not possible to repair IMEI (Write Cert), if phone's modem part is damaged. If after of writing all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). Last edited by Octopus box; 04-09-2015 at 06:32. | |
04-08-2015, 19:43 | #4 (permalink) | |
Banned Join Date: Mar 2015
Member: 2371548 Status: Offline Thanks Meter: 27 | Quote:
It has been posted at least a dozen times on this forum that there is no need to wipe efs on Verizon phones. They come factory unlocked and do not have an MSL code. So there is no reason to wipe the efs to wipe the MSL. All you do with verizon phones is write cert via UART and match MEID with new IMEI. That simple. Takes a minute and no root required. | |
08-26-2015, 18:12 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. You can "Write Cert" via USB cable, but not at all phone models which are available in Software this option is available. |
