10-22-2017, 21:19 | #1 (permalink) |
Junior Member Join Date: May 2017
Member: 2721209 Status: Offline Thanks Meter: 1 | SM-G920A cannot flash stock, repair modem |
10-23-2017, 07:45 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, try to reflash the phone with latest firmware version from the Support Area, then post here (or send us to PM, if You can't post here) full Software log, we will check. Last edited by Octopus box; 10-23-2017 at 09:17. |
10-23-2017, 21:25 | #4 (permalink) |
Member: 2721209 Status: Offline Thanks Meter: 1 | I try to post output but GSM Forum prevents me from sending PM or posting it Firmware write failed, BOOTLOADER, PARAM, CM write successfully BOOT fails File used is g920aucu1aoce_g920aatt1aoce_att_android_5.0.2 DOT OCT I am in blue screen that says update error, but it appears to be DOWNLOAD MODE because I can attempt reflash I go into Advanced Mode to disable Hidden but there is no hidden |
10-24-2017, 07:33 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You can't post here full Software log, please contact with us via Skype, we will check where can be the problem. |
10-25-2017, 08:38 | #10 (permalink) |
Member: 2721209 Status: Offline Thanks Meter: 1 | I am not asking of support of ODIN, Octoplus is not even connecting to write EFS or flash recovery and I cannot provide logs because of GSM Forum restrictions. I was temp banned for a day trying to send PM's. I can only post until logs are sent. |
10-26-2017, 06:03 | #13 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
Also, You can contact us to Skype, our contacts You can find in our profile. | |
10-26-2017, 10:55 | #14 (permalink) | |
Member: 2721209 Status: Offline Thanks Meter: 1 | Quote:
256406223 tombook: is this octoplus Your previous message could not be successfully delivered to the recipient. Please try again I will try to flash software backup first, then update Octoplus on this computer before attempt again. Now that I am at 10 posts I can post logs You say to flash with different firmwares, but I do not understand since there is no root for 6.0.1. Asking to update to 6.0.1. with baseband, HW modem unknown and IMEI null/null is asking to brick the phone, because I cannot root the phone to repair IMEI moreover, you have not answered my question about IMEI. on qualcomm device, IMEI is read in the Read info output. But when i Read Info on Exynos, IMEI is listed as XXXXX- and not in the output, even though this is a new, unrooted phone is because of lock?? both phone is lock and I intended to unlock, but wanted to repair null/null first. | |
10-26-2017, 21:13 | #15 (permalink) |
Member: 2721209 Status: Offline Thanks Meter: 1 | write security backup Welcome to Octoplus/Octopus Box Samsung software version 2.6.0 ----------------------------------------------------------------------------------- To connect SM-G920A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G920A Reading info, please wait... Detected phone model: SM-G920A Firmware compiled date: Fri Mar 27 01:22:10 KST 2015 PDA version: G920AUCU1AOCE CSC version: G920AATT1AOCE SW version: G920AUCU1AOCE Phone SN: Android version: 5.0.2 (LRX22G) Sales code: ATT Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 SIM 1 status: absent Codename: zeroflteuc Performed by 2.6.0 Software version. there is baseband but IMEI is 000000000000000 when I go to write IMEI it is XXXXXXXXXXXXXX|X this is how phone was when I receive it. no IMEI in output, different from Qualcomm which lists IMEI in output Galaxy S6 marshmallow has the same appeareance with XXXXXXXXXXXXXX|X |
