04-14-2016, 06:26 | #1 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 600277 Status: Offline Thanks Meter: 29 | sm-g920f 6.0.1 successful unlock enable usb debugging. here's the log: Welcome to Octoplus/Octopus Box Samsung software version 2.2.3 ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-G920FD phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM64 Selected model: SM-G920FD Please, press "OK" button on the phone to allow USB debugging.. Warning: Selected model (SM-G920FD) differs from the detected one (SM-G920F)! If you want select (SM-G920F) as (SM-G920FD) model, please check "manual select". Phone unlocking failed Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM64 Selected model: SM-G920FD Warning: Selected model (SM-G920FD) differs from the detected one (SM-G920F)! If you want select (SM-G920F) as (SM-G920FD) model, please check "manual select". Read codes failed Performed by 2.2.3 software version ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM64 Selected model: SM-G920F Detected phone model: SM-G920F Firmware compiled date: Thu Mar 17 04:25:01 KST 2016 PDA version: G920FXXU3DPCI CSC version: G920FOLB3DPC5 SW version: G920FXXU3DPC2 Phone SN: RF8G40CLQ0T Android version: 6.0.1 (MMB29K) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920F-Unknown14-04-2016_13-09-31-.asec file Deactivating MSL... Executing exploit... Exploit has been executed successfully MSL deactivate successfully Reading phone unlock codes. It can take some time, please wait... FREEZE unlock code: 15391742 NET LOCK unlock code: 72520290 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:31 Performed by 2.2.3 software version Last edited by Octopus box; 04-14-2016 at 11:18. |
The Following 2 Users Say Thank You to oman99 For This Useful Post: |
