06-14-2016, 13:23 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to write "SBOOT_G920F_OJ1" Sboot file from the Support Area as a firmware, then repeat "Reset FRP/Reactivation/EE" operation. Post here result and full Software log of performed operations. |
06-15-2016, 19:55 | #5 (permalink) |
No Life Poster Join Date: Sep 2002 Location: south Afrika Age: 38
Member: 15156 Status: Offline Thanks Meter: 73 | INFO : 6/15/2016 4:56:20 AM > To connect SM-G920F phone you have to perform the following steps: INFO : 6/15/2016 4:56:20 AM > 1. Disconnect USB cable from phone. INFO : 6/15/2016 4:56:20 AM > 2. Go to Menu->Settings->More->About Device. INFO : 6/15/2016 4:56:20 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/15/2016 4:56:20 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/15/2016 4:56:20 AM > 5. Turn on "USB Debugging" option. INFO : 6/15/2016 4:57:02 AM > Selected firmware file: SBOOT_G920F_OJ1.oct INFO : 6/15/2016 4:57:30 AM > ----------------------------------------------------------------------------------- INFO : 6/15/2016 4:57:31 AM > Platform: Samsung Android INFO : 6/15/2016 4:57:31 AM > Selected port: COM7 INFO : 6/15/2016 4:57:31 AM > Selected model: SM-G920F WARN : 6/15/2016 4:57:31 AM > To put SM-G920F into Download Mode, You have to perform the following steps: WARN : 6/15/2016 4:57:31 AM > 1. Reconnect the battery. WARN : 6/15/2016 4:57:31 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 6/15/2016 4:57:31 AM > 3. When phone turns on, press "Volume+" key. INFO : 6/15/2016 4:57:31 AM > Searching for a phone. Please wait... INFO : 6/15/2016 4:57:31 AM > Phone found. INFO : 6/15/2016 4:57:31 AM > Initializing.. INFO : 6/15/2016 4:57:31 AM > Resetting FRP lock.. SUCC : 6/15/2016 4:57:31 AM > success INFO : 6/15/2016 4:57:31 AM > Resetting EE lock.. SUCC : 6/15/2016 4:57:32 AM > success INFO : 6/15/2016 4:57:32 AM > Resetting Samsung Account lock.. ERROR : 6/15/2016 4:57:41 AM > Operation was failed! INFO : 6/15/2016 4:57:42 AM > Performed by 2.2.7 software version WARN : 6/15/2016 4:58:18 AM > Please put the phone into Download Mode and connect USB cable. WARN : 6/15/2016 4:58:18 AM > To put SM-G920F into Download Mode, You have to perform the following steps: WARN : 6/15/2016 4:58:18 AM > 1. Reconnect the battery. WARN : 6/15/2016 4:58:18 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 6/15/2016 4:58:18 AM > 3. When phone turns on, press "Volume+" key. INFO : 6/15/2016 4:58:18 AM > Found phone on INFO : 6/15/2016 4:58:18 AM > Firmware write started. INFO : 6/15/2016 4:58:18 AM > Writing BOOTLOADER section... INFO : 6/15/2016 4:58:21 AM > BOOTLOADER section has been written successfully. INFO : 6/15/2016 4:58:21 AM > Firmware writing successfully completed. INFO : 6/15/2016 4:58:21 AM > Performed by 2.2.7 software version INFO : 6/15/2016 5:00:58 AM > ----------------------------------------------------------------------------------- INFO : 6/15/2016 5:01:00 AM > Platform: Samsung Android INFO : 6/15/2016 5:01:00 AM > Selected port: COM3 INFO : 6/15/2016 5:01:00 AM > Selected model: SM-G920F WARN : 6/15/2016 5:01:00 AM > To put SM-G920F into Download Mode, You have to perform the following steps: WARN : 6/15/2016 5:01:00 AM > 1. Reconnect the battery. WARN : 6/15/2016 5:01:00 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 6/15/2016 5:01:00 AM > 3. When phone turns on, press "Volume+" key. INFO : 6/15/2016 5:01:00 AM > Searching for a phone. Please wait... INFO : 6/15/2016 5:01:00 AM > Phone found. INFO : 6/15/2016 5:01:00 AM > Initializing.. INFO : 6/15/2016 5:01:00 AM > Resetting FRP lock.. SUCC : 6/15/2016 5:01:00 AM > success INFO : 6/15/2016 5:01:00 AM > Resetting EE lock.. SUCC : 6/15/2016 5:01:00 AM > success INFO : 6/15/2016 5:01:00 AM > Resetting Samsung Account lock.. SUCC : 6/15/2016 5:01:00 AM > success WARN : 6/15/2016 5:01:00 AM > Reset operation completed! INFO : 6/15/2016 5:01:12 AM > Performed by 2.2.7 software version |
06-16-2016, 12:27 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to reflash the phone, then root it again. Are any errors appear on screen while in Recovery Mode, or during boot? |
06-16-2016, 12:39 | #11 (permalink) |
Member: 15156 Status: Offline Thanks Meter: 73 | no errors but when i try to flash gives error odin mode product name:sm-g920f current binary:custom system statusfficial reactivation lockff secure download:enabled knox warranty void 1(0x0500) ap swrev b:3 k:2 s:2 sw rev.check fail. device :3, binary :2 (what does this mean) every tym i try to flash gives the same error can you help me please |
06-16-2016, 13:12 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You should write any firmware with the same Android version, as has the phone. If You are not sure about Android version - use Android 6.0.1 firmware. |
