01-16-2016, 11:14 | #1 (permalink) |
Insane Poster Join Date: Jan 2006 Location: Ha Noi - Viet Nam
Member: 220723 Status: Offline Thanks Meter: 23 | SM-G920F problem ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J700F Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Sep 25 16:07:03 KST 2015 PDA version: G920FXXU3COI9 CSC version: G920FVIR3COJ1 SW version: G920FXXU3COI9 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J700F Warning: Selected model (SM-J700F) differs from the detected one (SM-G920F)! If you want select (SM-G920F) as (SM-J700F) model, please check "manual select". Phone unlocking failed ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM112 Selected model: SM-G920F Selected file: C:\Users\admin\Desktop\cert-sm-g920f_ 352127070034405_rf8g4276vpp.cert Detected phone model: SM-G920F Firmware compiled date: Fri Sep 25 16:07:03 KST 2015 PDA version: G920FXXU3COI9 CSC version: G920FVIR3COJ1 SW version: G920FXXU3COI9 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as D:\Program files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920F-Unknown16-01-2016_17-10-27-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully << end this can't continue! please help me |
01-16-2016, 13:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please do the next: 1. Install test Software version. 2. Make Factory Reset and reflash the phone. 3. Root the phone with CF Auto Root. 4. Remove SIM card from the phone. 5. Write First Security backup back into the phone. 6. Repeat "Write Cert" operation. Post here result and full Software log of performed operations. |
