11-14-2018, 12:59 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | SM-G920i U4 7.0 Reactivation ON - Any Solution? [Answered] G920i U4 7.0 Reactivation ON - Any Solution ? Last edited by Octopus box; 11-14-2018 at 16:10. |
11-14-2018, 13:19 | #2 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Sky Mobile™
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | 1. Flash BOOT , Recovery , System , Cache From this firmware (G920IDVS3EQA7) 2.after flash 3.contact to wifi go again to wifi setting 4.choose a wifi and go to advance setting of wifi write (any) in api setting select (any) word, you will have (Google Assistant) 5.go to setting then make hard reset 6. the device will ask you for samsung account (new account) >>> (Just login with your samsung account) after that 7. go to https://findmymobile.samsung.com 8. login with same email which you added to the device make unlock all done |
The Following User Says Thank You to naazerkhan For This Useful Post: |
11-14-2018, 16:09 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hi. Also You can reset Samsung Account (Reactivation Lock) via Octoplus Samsung Reset FRP / Reactivation Service only via connecting USB cable and pressing one button. But operation is not free and require Octoplus Server Credits, please look here: http://forum.gsmhosting.com/vbb/f684...018-a-2263590/. |
11-16-2018, 21:57 | #5 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | hello, for android 7 use and make the flash of the combination compatible with the binary sel firmware installed on your phone, then repair the drk via uart cable through octopus software, this is the only way to repair the drk if using the root using the twrp or cf auto root you could not start the phone and do the drk fix. |
11-16-2018, 22:19 | #6 (permalink) | |
Member: 1789551 Status: Offline Thanks Meter: 90 | Quote:
