08-27-2016, 14:01 | #1 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Sri Lanka Age: 34
Member: 1615710 Status: Offline Sonork: 100.1647890 Thanks Meter: 260 | SM-G920R7 GSM networks?? I have SM-G920R7 CDMA phone according to some info from internet this model must use GSM networks but when we insert a sim it's detecting but but shows no service. I tried connecting using manual select with G920R4 and write cert. but it shows following error. Plz guide me to ahead. I have 5 set of his model. and 2 of SM-G925R7 looking forward o hear soon. Thanks. Welcome to Octoplus/Octopus Box Samsung software version 2.3.4 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-G920R4 Reading info, please wait... Warning: Selected model (SM-G920R4) differs from the detected one (SM-G920R7)! If you want select (SM-G920R7) as (SM-G920R4) model, please check "manual select". Performed by 2.3.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-G920R4 Reading info, please wait... Detected phone model: SM-G920R7 Firmware compiled date: Wed Mar 2 13:42:26 KST 2016 PDA version: G920R7WWU3CPC1 CSC version: G920R7ACG3CPC1 SW version: G920R7WWU3CPC1 Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Sales code: ACG Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: MDM9635M Codename: zeroflteacg Performed by 2.3.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-G920R4 Selected file: C:\Users\Modern Tech\Downloads\cert-sm-g925t_ 359146060529706_r58g5024pct.cert Detected phone model: SM-G920R7 Firmware compiled date: Wed Mar 2 13:42:26 KST 2016 PDA version: G920R7WWU3CPC1 CSC version: G920R7ACG3CPC1 SW version: G920R7WWU3CPC1 Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Sales code: ACG Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: MDM9635M Codename: zeroflteacg Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed Performed by 2.3.4 software version |
08-27-2016, 14:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Unfortunately SM-G920R7 is not supported at the moment. On your own risk You can try to make unlock as for SM-G920R4. |
08-27-2016, 20:25 | #3 (permalink) |
Member: 1615710 Status: Offline Sonork: 100.1647890 Thanks Meter: 260 | I have try unlocking is done but nothing happened. Kindly let me know witch hardware key ID support for this I need write cert file for this. |
08-29-2016, 07:25 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | KeyID of SM-G920R7 is 0053. Once again, this model is not supported at the moment and all operations, which You perform with the phone are performed on your own risk. |
08-29-2016, 08:58 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please do the next: 1. Perform "Unlock" operation again. 2. Check status of IMEI Certi in *#0011# menu. 3. Insert SIM card of GSM Network provider. 4. Check whether GSM/(E)GPRS/WCDMA GCF is enabled in your phone: 1. Open hidden menu. There are two ways of doing it: 1) Run the following command via ADB: Code: adb shell su -c "am broadcast -a android.provider.Telephony.SECRET_CODE -d android_secret_code://IOTHIDDENMENU" 2) Perform the following actions: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". 2. After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following: I.
II.
After these actions go to Settings -> Mobile Networks and Set Network Mode to Automatic, or GSM. |
The Following 3 Users Say Thank You to Octopus box For This Useful Post: |
