06-18-2017, 00:52 | #1 (permalink) |
Major Poster Join Date: Jan 2017 Location: turkey Age: 36
Member: 2673822 Status: Offline Thanks Meter: 7 | sm-n9005 doesn't register on network |
06-18-2017, 10:37 | #2 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2474048 Status: Offline Thanks Meter: 0 | check the imei. i may be blacklisted... befor you write the cert.. go to any website to check that imei or that cert... i had the same problem before.. some cert has a blacklisted imei. Sent from my SM-G935T using Tapatalk |
06-19-2017, 07:31 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. If after writing of a Cert file problem with network remains - most likely Cert file is blacklisted. You can try to write different Cert files. Also You can read Cert file from SM-N900, which has no issues with network, then use it for your phone. Cert files of SM-N900 are compatible with SM-N9005 (Cert files compatibility). |
06-19-2017, 19:10 | #7 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
