05-27-2018, 13:10 | #1 (permalink) |
Junior Member Join Date: May 2018
Member: 2840390 Status: Offline Thanks Meter: 1 | SM-G925F error even in combination [Answered] Turned out its something deeper. I lost two days flashing stock nougat roms all the time. I have tried single file firmwares , also 4file repair firmwares and everything is on the same faith. After flashing with odin phone reboots, gets into updating screen for 2-3 seconds,starting right from 25% to 32% then goes to updating screen, the animation freeze and phone becomes unresponsive. If i reboot and try to enter recovery i get a no command screen,Sometimes it jumps into recovery after no command screen but then again freezes. I tried and flashed combination rom binary 6. It passed the first boot screen and the updating screen, on the gear spinning animation i got the samsung sound but after a while animation froze and again after a while i got a bootloader error RST_STAT = 0x100000 Tried also to access recovery but ended on rst_stat=0x10000 or 0x20000. Last edited by Octopus box; 05-28-2018 at 13:05. |
05-27-2018, 16:33 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
You have to put the phone in dowload mode and flash the firmware of the file in 4 files and see if it is back in place | |
05-27-2018, 17:29 | #3 (permalink) | |
Member: 2840390 Status: Offline Thanks Meter: 1 | Quote:
I Used COMBINATION_OXA_FA50_G925FXXU6ARC1_BOXWares that one which i saw that is compatible with binary 6. I get bootloader exception screen (without anywhere writing that) but the rest are exact the same. I have tried many stock firmwares both one file and 4 files including pit. Everything just not boots. With stock firmwares i usually end in a situation where phone freezes for hours on erasing screen. Then i can only get into odin mode, recovery gives me no command screen. With combination my luck was that after flash phone would freeze on grinding gears and give me exception screen. Same was going for recovery. For somereason i'm now able to boot into combination rom, BUT after 30 seconds phone freezes and get error screen again(watchdog reset screen with the rst_stat etc Same goes for recovery on combination rom. Last edited by razenxd; 05-27-2018 at 17:35. | |
05-27-2018, 17:59 | #4 (permalink) | |
05-27-2018, 18:05 | #5 (permalink) | |
i dunno what firmware it used to have before crash. I have tried flashed the latest BTU and EUR firmware (both 1 file and 4 file ones) G925FXXU6ERC9_G925FVFG6ERCA_G925FXXU6ERC9_HOME G925FXXU6ERC9_G925FBTU6ERC3_G925FXXU6ERC2_HOME and others but everyone gives me the same attitude. After flash reboots, then updating screen skips to 32% and then phone Freeze (animation also) in the updating screen. | |
05-27-2018, 18:22 | #6 (permalink) | |
then it depends which bootloop was if stuck on the boot logo and if you tried before putting it in recovery mode if it came in there was written the firmware pda to understand the compatibility between installed firmware and combination | |
The Following User Says Thank You to amleto90 For This Useful Post: |
05-27-2018, 18:24 | #7 (permalink) | |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Quote:
Did u try to flash it wit PIT file.? If not yet than Add PIT nd flash it wit repartition ..[open CSC wit ZIP Extractor nd extract PIT file from it ]if still same than it may b Hardware issue [water Damaged or Emmc corrupted.] | |
The Following User Says Thank You to -Mosin- For This Useful Post: |
05-27-2018, 18:36 | #9 (permalink) | ||
Could also when i flash a stock firmware and phone freezes, that could be a bootloader exception just without the error screen comes up? Quote:
Somebody told me to download that single file firmware G925FXXU6ERD3_G925FOJV6ERD2_ACR and flash it along with a .pit file(need to search that one since it's not inside) But on 4files repair firmwares i tried in the csc there was a pit file which i didn't extract and had repartition on, since odin use the pit to map if its in the csc right? If emmc is corrupted, the only way to fix is by replacing the chip right? | ||
05-27-2018, 23:39 | #10 (permalink) |
Member: 2840390 Status: Offline Thanks Meter: 1 | Flashed U6 Firmware along with its extracted PIT file Got back to froze animation in erasing screen and then reboot to no command screen without access to recovery. Got out the back cover, board seems fine not water damage which can be seen. Disconnect reconnect everything, flashed combination rom again phone still freezes and gives bootloader exceptions. Well i guess the UFS chip is more than dead. |
05-28-2018, 13:05 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Most likely, device has HW problem(s). Please check HW. |
