07-17-2017, 14:49 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Haiti
Member: 1299439 Status: Offline Thanks Meter: 77 | SM-G925T FRP help needed. |
07-17-2017, 15:04 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. Please reflash the phone with Smart Switch, or manually, using an original firmware. After this You can reset FRP via "Reset FRP/Reactivation/EE" operation. |
07-17-2017, 15:36 | #5 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hello the problem you did the firmware flash with binary 3 revision when the phone had a binary revision firmware 5 so to make it fuse again make the original firmware flash you had on the phone using smartswitch or flashing with odin then If you want to rewrite the firmware flash you need to have a firmware with binary 5 compatible revision otherwise the phone locks |
07-17-2017, 16:02 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Quote:
07-17-2017, 16:49 | #8 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | If it is not supported by smartswitch you must download the original stock firmware that you had before trying to flash another firmware otherwise you root with cf autoroot the phone resumes |
07-17-2017, 16:55 | #9 (permalink) |
No Life Poster Join Date: May 2009 Location: USA/NY
Member: 1025079 Status: Offline Thanks Meter: 311 | Download later version of software that will solve it. look for this G925TUVU5FQE1 Last edited by cwcast; 07-17-2017 at 17:00. |
The Following User Says Thank You to cwcast For This Useful Post: |
07-19-2017, 01:13 | #10 (permalink) |
Registered User Join Date: Mar 2012 Location: St Augustine Florida USA
Member: 1728372 Status: Offline Thanks Meter: 23 | The g925t should be supported by smart switch. Are you putting the device in download mode, in smart switch going to Emergency Recovery mode device initialization, entering the model number shown like this SM-G925T, search, then entering the serial number? |
The Following User Says Thank You to devicesnow For This Useful Post: |
