12-16-2016, 05:45 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Sky Mobile™
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | SM-G925W8 unlock problame ----------------------------------------------------------------------------------- To connect SM-G920W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G920W8 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G920W8 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G920W8 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G920W8 Please, press "OK" button on the phone to allow USB debugging.. Warning: Selected model (SM-G920W8) differs from the detected one (SM-G925W8)! If you want select (SM-G925W8) as (SM-G920W8) model, please check "manual select". Phone unlocking failed Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- To connect SM-G925W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Detected phone model: SM-G925W8 Firmware compiled date: Mon Sep 12 14:27:12 KST 2016 PDA version: G925W8VLU5CPI4 CSC version: G925W8OYA5CPI4 SW version: G925W8VLU5CPI4 Phone SN: R58G7025X7M Android version: 6.0.1 (MMB29K) Sales code: BMC Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-09-01 Codename: zeroltebmc Checking Root: Phone is not Rooted. Phone unlocking failed Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Searching for a phone. Please wait... Found phone on COM18 Reading info... Detected phone model: SM-G925W8 HW Version: SM-G925WZKEBMC PDA version: G925W8VLU5CPI4 CSC version: G925W8OYA5CPI4 CP version: G925W8VLU5CPI4 Phone SN: R58G7025X7M Phone IMEI: 358758-06-214462-2 Reading codes... Fast Read Codes method is not supported for current security settings in your phone! Try to downgrade firmware! Read codes failed Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Detected phone model: SM-G925W8 Firmware compiled date: Mon Sep 12 14:27:12 KST 2016 PDA version: G925W8VLU5CPI4 CSC version: G925W8OYA5CPI4 SW version: G925W8VLU5CPI4 Phone SN: R58G7025X7M Android version: 6.0.1 (MMB29K) Sales code: BMC Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-09-01 Codename: zeroltebmc Deactivating MSL... Read codes failed Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Detected phone model: SM-G925W8 Firmware compiled date: Mon Sep 12 14:27:12 KST 2016 PDA version: G925W8VLU5CPI4 CSC version: G925W8OYA5CPI4 SW version: G925W8VLU5CPI4 Phone SN: R58G7025X7M Android version: 6.0.1 (MMB29K) Sales code: BMC Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-09-01 Codename: zeroltebmc Deactivating MSL... Executing exploit... Executing exploit failed Read codes failed Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Detected phone model: SM-G925W8 Firmware compiled date: Mon Sep 12 14:27:12 KST 2016 PDA version: G925W8VLU5CPI4 CSC version: G925W8OYA5CPI4 SW version: G925W8VLU5CPI4 Phone SN: R58G7025X7M Android version: 6.0.1 (MMB29K) Sales code: BMC Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-09-01 Codename: zeroltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Security read successfully. Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925W8 Detected phone model: SM-G925W8 Firmware compiled date: Mon Sep 12 14:27:12 KST 2016 PDA version: G925W8VLU5CPI4 CSC version: G925W8OYA5CPI4 SW version: G925W8VLU5CPI4 Phone SN: R58G7025X7M Android version: 6.0.1 (MMB29K) Sales code: BMC Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-09-01 Codename: zeroltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G925W8-Unknown16-12-2016_10-05-56-.asec file Deactivating MSL... Executing exploit... Executing exploit failed Phone unlocking failed Performed by 2.4.6 Software version. |
12-16-2016, 09:29 | #3 (permalink) |
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.6 ----------------------------------------------------------------------------------- To connect SM-G925W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925W8 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925W8 Firmware compiled date: Mon Sep 12 14:27:12 KST 2016 PDA version: G925W8VLU5CPI4 CSC version: G925W8OYA5CPI4 SW version: G925W8VLU5CPI4 Phone SN: R58G7025X7M Android version: 6.0.1 (MMB29K) Sales code: BMC Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-09-01 Codename: zeroltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G925W8-Unknown16-12-2016_13-53-20-.asec file Deactivating MSL... Executing exploit... Executing exploit failed Phone unlocking failed Performed by 2.4.6 Software version. after flash same how to fix octoplus team |
12-16-2016, 09:37 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Your phone has one of the latest firmwares with new type of Security. To unlock such phone You can try to write older (by release date) firmware. |
12-16-2016, 10:07 | #5 (permalink) |
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.6 ----------------------------------------------------------------------------------- To connect SM-G925W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925W8 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925W8 Firmware compiled date: Mon Sep 12 14:27:12 KST 2016 PDA version: G925W8VLU5CPI4 CSC version: G925W8OYA5CPI4 SW version: G925W8VLU5CPI4 Phone SN: R58G7025X7M Android version: 6.0.1 (MMB29K) Sales code: BMC Country: Canada HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-09-01 Codename: zeroltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G925W8-Unknown16-12-2016_13-53-20-.asec file Deactivating MSL... Executing exploit... Executing exploit failed Phone unlocking failed Performed by 2.4.6 Software version. Selected firmware file: G925W8VLU3CPC5_G925W8OYA3CPC5_GLW_Android_6.0.1.oc t Please put the phone into Download Mode and connect USB cable. To put SM-G925W8 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.4.6 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-G925W8 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.4.6 Software version. try to write older (by release date) firmware failed. SW REV, CHECK FAIL. DEVICE: 4, BINARY: 3 |
12-16-2016, 10:11 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Such error means that downgrading is not possible for current firmware of the phone. If phone requests unlock code - You can use Factory Unlock service. Otherwise, unfortunately, no solution at the moment. |
