04-12-2017, 09:37 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Octoplus Team
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | SM-G930F flashing failed always... [Solved] I have a big problem with sm-g930f. My phone version is 7 nougat. I decided root with cf-autoroot this version CF-Auto-Root-herolte-heroltexx-smg930f but odin failed. Now i cant write firmware always failed: Code: <ID:0/026> Added!! <ID:0/026> Odin engine v(ID:3.1203).. <ID:0/026> File analysis.. <ID:0/026> SetupConnection.. <ID:0/026> Initialzation.. <ID:0/026> FAIL! (DeviceInfo) <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/026> Removed!! Code: Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\12-04-2017_13-29-13.log" created (12.04.2017 13:29:16). INFO : 12.04.2017 13:29:27 > Set up system language Russian (file: Russian - копия.ini) INFO : 12.04.2017 13:29:28 > Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 INFO : 12.04.2017 13:29:36 > ----------------------------------------------------------------------------------- INFO : 12.04.2017 13:29:36 > To connect SM-G930FD phone you have to perform the following steps: INFO : 12.04.2017 13:29:36 > 1. Disconnect USB cable from phone. INFO : 12.04.2017 13:29:36 > 2. Go to Menu->Settings->More->About Device. INFO : 12.04.2017 13:29:36 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 12.04.2017 13:29:36 > 4. Go to Menu->Settings->More->Developer options. INFO : 12.04.2017 13:29:36 > 5. Turn on "USB Debugging" option. INFO : 12.04.2017 13:30:05 > Selected AP file: E:\+++\FIRMWARE\G930FXXU1DQAS_G930FOJV1DQAT_XSG\AP_G930FXXU1DQAS_CL10273029_QB12269014_REV00_user_low_ship_meta.tar INFO : 12.04.2017 13:30:05 > Selected CP file: E:\+++\FIRMWARE\G930FXXU1DQAS_G930FOJV1DQAT_XSG\CP_G930FXXU1DQA3_CL10273029_QB12139038_REV00_user_low_ship.tar INFO : 12.04.2017 13:30:05 > Selected CSC file: E:\+++\FIRMWARE\G930FXXU1DQAS_G930FOJV1DQAT_XSG\CSC_OJV_G930FOJV1DQAT_CL10415117_QB12275417_REV00_user_low_ship.tar WARN : 12.04.2017 13:30:06 > Please put the phone into Download Mode and connect USB cable. WARN : 12.04.2017 13:30:06 > To put SM-G930FD into Download Mode, You have to perform the following steps: WARN : 12.04.2017 13:30:06 > 1. Reconnect the battery. WARN : 12.04.2017 13:30:06 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 12.04.2017 13:30:06 > 3. When phone turns on, press "Volume+" key. INFO : 12.04.2017 13:30:06 > Found phone on INFO : 12.04.2017 13:30:06 > Firmware write started. ERROR : 12.04.2017 13:30:07 > Writing Firmware Failed INFO : 12.04.2017 13:30:07 > Performed by 2.4.7 Software version. I understood my mistake Nougat 7 version I write marshmallow root version Last edited by Octopus box; 04-20-2017 at 07:31. |
04-12-2017, 09:50 | #2 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | The root is for 6.0.1 not 7! Code: samsung SM-G930F heroltexx herolte universal8890 exynos5 MMB29K.G930FXXU1BPH6 6.0.1 BR, |
04-12-2017, 10:16 | #3 (permalink) | |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | Thanks brother But now my phone only samsung logo cant write firmware always failed Quote:
04-12-2017, 10:16 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please install the latest Software version, then repeat "Write Firmware" operation. Post here the result. |
04-12-2017, 10:33 | #5 (permalink) | |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | Stil same problem brother please explain me how to solve The phone version was nougat 7.0 i suddenly write marshmallow 6.0.1 root file then didnt power on my phone only ding ding vibration and samsung logo please solve my problem thanks. Quote:
04-12-2017, 10:33 | #6 (permalink) | |
04-12-2017, 10:45 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write "G930FXXU1DQC4_G930FOJV1DQC6_XSG_Android_7" firmware from the Support Area and post here the result. |
04-13-2017, 14:34 | #9 (permalink) |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | My problem solved the phone power on but only emergency call. I do root the phone and unlock with octoplus box unlock succesfully is done but other problem baseband unknown and unknown imei. How to solve this problem ? thanks team. |
04-13-2017, 16:18 | #11 (permalink) |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | ----------------------------------------------------------------------------------- Платформа: Samsung Android Выбранный порт: COM25 Выбранная модель: SM-G930F Please, press "OK" button on the phone to allow USB debugging.. Определена модель телефона: SM-G930F Дата создания прошивки: Mon Jan 16 19:17:01 KST 2017 PDA version: G930FXXU1DQAS CSC version: G930FOJV1DQAT Версия программного обеспечения: unknown Phone SN: RF1D45EJGGR Android version: 7.0 (NRD90M) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos8890 HW Modem: unknown Security patch level: 2017-01-01 Codename: heroltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G930F-Unknown13-04-2017_20-14-38-.asec file Connecting to modem port... Modem port was not found! Initializing exploit... Executing exploit... Exploit has been executed successfully Разблокировка телефона... Телефон успешно разблокирован To finish the operation, please restart the phone via phone's menu. Performed by 2.5.1 Software version. [/QUOTE] |
04-14-2017, 08:30 | #14 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | According to Software log, phone's modem was already damaged during "Unlock" operation: Quote:
If You have earlier Security backup - write it into the phone, then perform "Unlock" operation again. Otherwise You should try to re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). When phone's modem part will be correct - check the Network. | |
