08-13-2018, 08:57 | #1 (permalink) |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | SM-G935A Factory Reset Protection Successfully erased Log of the operation/ Code: Welcome to Octoplus Box Samsung software version 2.7.0 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G935A Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)... Reading info... Detected phone model: SM-G935A Firmware compiled date: Sat Nov 5 17:53:50 KST 2016 PDA version: G935AUCS4APK1 CSC version: G935AATT4APK1 SW version: G935AUCU6ARC1 Phone SN: R38H506DG4X Android version: 6.0.1 (MMB29M) Sales code: ATT Country: USA HW platform: msm8996 HW Chip: MSM8996 HW Modem: MSM8996 Security patch level: 2016-11-01 Warranty Void: 0 SIM 1 status: absent Codename: hero2qlteuc Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.7.0.3 Software version. |
The Following 2 Users Say Thank You to lyes_albert For This Useful Post: |
11-13-2018, 03:58 | #2 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2341684 Status: Offline Thanks Meter: 1 | I have a problem after installing that combination a question, after you had installed the combination G935AUCU6ARC1 , with which rom or flash you got it from there to finish the process of frp remove and which was compatible with that binary 6, I could not install a compatible rom for that binary, my phone is G935T, thanks for your information |
The Following User Says Thank You to waltandres For This Useful Post: |
11-13-2018, 19:38 | #5 (permalink) | |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Quote:
The log points out to binary 4. So, after installing the Comfile *Boot.img*, ADB will be enabled, if you have a full firmware, then flash the whole of it, then write full stock......make sure you untick user data prior to writing the firmware/ system+sboot+boot+recovery+cache Note/ There are all types of combfiles on support area Last edited by lyes_albert; 11-13-2018 at 19:47. | |
The Following User Says Thank You to lyes_albert For This Useful Post: |
11-13-2018, 19:54 | #6 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | In order to finish the process if you choose to flash the full combination, as you have asked, then you need the following firmware....B4 not B6, |
