07-20-2016, 22:28 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Canada Age: 44
Member: 169896 Status: Online Thanks Meter: 323 | SM-G935W8 Unlock Done Successfully with Reading Codes Selected port: COM15 Selected model: SM-G935W8 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G935W8 Firmware compiled date: Fri Feb 12 02:29:50 KST 2016 PDA version: G935W8VLU1APB7 CSC version: G935W8OYA1APB7 SW version: G935W8VLU1APB7 Phone SN: RF8H52671NZ Android version: 6.0.1 (MMB29K) Country: Canada HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Codename: hero2ltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G935W8-Unknown20-07-2016_14-20-15-.asec file Initializing exploit... Executing exploit... Exploit has been executed successfully Reading phone unlock codes. It can take some time, please wait... FREEZE unlock code: 86174020 NET LOCK unlock code: 03624150 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:54 |
10-26-2016, 07:26 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You can try to find root method here: http://forum.gsmhosting.com/vbb/f606.../#post10637865 |
02-27-2017, 13:06 | #6 (permalink) |
Freak Poster Join Date: Aug 2011 Location: ganganagar
Member: 1627229 Status: Offline Thanks Meter: 48 | here is without root :) Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-G930W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G930W8 Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G930W8 Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Warning: Selected model (SM-G930W8) differs from the detected one (SM-G935W8)! If you want select (SM-G935W8) as (SM-G930W8) model, please check "manual select". Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- To connect SM-G935W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G935W8 Reading info, please wait... Detected phone model: SM-G935W8 Firmware compiled date: Fri Nov 18 19:04:06 KST 2016 PDA version: G935W8VLU2APK3 CSC version: G935W8OYA2APK3 SW version: G935W8VLU2APK3 Phone SN: RF8H82EW5QL Android version: 6.0.1 (MMB29K) Sales code: GLW Country: Canada HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Security patch level: 2016-11-01 Codename: hero2ltebmc Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G935W8 Searching for a phone. Please wait... Found phone on COM4 Reading info... Detected phone model: SM-G935W8 HW Version: SM-G935WZKAGLW PDA version: G935W8VLU2APK3 CSC version: G935W8OYA2APK3 CP version: G935W8VLU2APK3 Phone SN: RF8H82EW5QL Phone IMEI: 356160-07-204935-8 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. It can take some time, please wait... FREEZE unlock code: 96270707 NET LOCK unlock code: 57409179 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:43 Performed by 2.4.7 Software version. |
The Following User Says Thank You to manish.kalra For This Useful Post: |
04-22-2017, 11:49 | #7 (permalink) |
Insane Poster Join Date: Apr 2014 Location: Shop # 34 HafeeZ Center,
Member: 2161392 Status: Offline Sonork: 100.1677520:hafiz Thanks Meter: 50 | g935w8 nougat unlock 10000000000000000 ok odel: SM-G935W8 Sales Code: RWC Country Code: Canada Timezone: Asia/Karachi Android Version: 7.0 [NRD90M] Build Date: Fri Feb 24 13:46:15 KST 2017 PDA Version: G935W8VLU2BQB6 [february 2017, rev6] Phone Version: G935W8VLU2API1 [september 2016, rev1] CSC Version: G935W8OYA2BQB6 [february 2017, rev6] Product Code: RWC HIDSw Version: G935W8VLU2BQB6/G935W8OYA2BQB6/G935W8VLU2API1/G935W8VLU2BQB6 Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: RF8H80QKG7M Imei: 356160071887295 Unique Number: CE071607C4B3A53203 Connections: AT,MTP Battery Status: 4.08V (74%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-02-01 Reading Codes... Please unlock screen lock if closed! Trying on SAMSUNG Mobile USB Modem (COM87) Processing. Be patient! Do NOT disconnect the phone! Calculating. MasterLock: 250248888 NetworkLock: 39252252 SubsetLock: 00000000 SpLock: 00000000 CpLock: 00000000 SimLock: 00000000 Finished successfully. Finished at local time: [04.21.17 19:38:20] WorkID: 20259411 circuit city .hafeez centre.shop# g.34 hafiz.jahangir/ph.009203214442394 downgrade just modem true odin first flash modem https://www.4shared.com/rar/7KM2WXby...e_g935w8.html? without root unloc 100000000000000000000 ok |
The Following 5 Users Say Thank You to jahangir_123 For This Useful Post: |
