06-12-2018, 20:10 | #1 (permalink) |
Freak Poster Join Date: Nov 2015
Member: 2488318 Status: Offline Thanks Meter: 31 | SM-G950U problem enter code [Solved] Welcome to Octoplus Box Samsung software version 2.6.9 ----------------------------------------------------------------------------------- To connect SM-G925T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-G950U Operation: Read Codes Proper android device not found. Make shure that "USB debug" option on the device is turned on. Read codes failed Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-G950U Operation: Read Codes Proper android device not found. Make shure that "USB debug" option on the device is turned on. Read codes failed Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-G950U Operation: Read Codes Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-G950U Firmware compiled date: Fri Nov 10 19:01:47 KST 2017 PDA version: G950USQU2BQK5 CSC version: G950UOYN2BQK5 SW version: G950USQU2BQK5 Phone SN: R38K100BBEA Android version: 7.0 (NRD90M) Sales code: ATT Country: USA HW platform: msm8998 HW Chip: MSM8998 HW Modem: MSM8998 Security patch level: 2017-11-01 SIM 1 status: network locked Codename: dreamqltesq Searching for USB diagnostic port... Reading info... Mode: Normal Firmware compiled date: Oct 31 2017 Firmware compiled time: 06:00:00 Firmware released date: Nov 10 2017 Firmware released time: 18:13:06 SW Version: MPSS.AT.2.0.c5-00539-8998_GEN_PACK- 1.120304.1.123007.1 Reading data...OK Connecting to server .. Username: mobiletoyzz Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 224 credits. ----------------------------------------------------------------------------------- Sending request...OK Calculating codes. Please wait... FREEZE: 25351606 NET LOCK: 26413938 SUB LOCK: 00000000 SP LOCK: 00000000 CP LOCK: 00000000 Performed by 2.6.9 Software version. Last edited by Octopus box; 06-17-2018 at 09:58. |
06-13-2018, 04:45 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. What code (type of code) does you device request exactly? Try to enter FREEZE code, wait 1-2 minutes and try to enter NET LOCK code. If the device still doesn't accept code, try to do Hard Reset or re-flash the device with another proper firmware and try to enter code again. |
