08-05-2015, 10:15 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: philippines
Member: 517175 Status: Offline Sonork: none Thanks Meter: 44 | SM-J100F unlock???? [Solved] is this unit SM-J100F supported or not in unlocking??? original firmware Platform: Samsung Android Selected port: COM57 Selected model: SM-J100H Detected phone model: SM-J100F Firmware compiled date: Thu May 14 17:54:43 KST 2015 PDA version: J100FXXU0AOE1 CSC version: J100FOJV0AOE1 SW version: J100FXXU0AOE2 Phone IMEI: 35755xxxxxxxxx Phone SN: R28G300924E Android version: 4.4.4 (KTU84P) Connecting to phone's modem port, please wait... Found phone on COM47 Reading phone unlock codes. It can take some time, please wait... flashing succes Welcome to Octoplus/Octopus Box Samsung software version 2.0.2 Selected firmware file: sm-j100f_xxu0aoa7_ojv0aoa7.oct Please put the phone into Download Mode and connect USB cable. To put SM-J100F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Found phone on Firmware write started. Writing SBOOT section... SBOOT section has been written successfully. Writing SBOOT2 section... SBOOT2 section has been written successfully. Writing LOKE1ST section... LOKE1ST section has been written successfully. Writing LOKE2ND section... LOKE2ND section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing DTimPrimary section... DTimPrimary section has been written successfully. Writing DTimRecovery section... DTimRecovery section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing SSTD section... SSTD section has been written successfully. Writing NVM section... NVM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing PIT section... PIT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. writing root succes Welcome to Octoplus/Octopus Box Samsung software version 2.0.2 Selected firmware file: sm-j100f_xxu0aoa7_ojv0aoa7.oct Please put the phone into Download Mode and connect USB cable. To put SM-J100F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Found phone on Firmware write started. Writing SBOOT section... SBOOT section has been written successfully. Writing SBOOT2 section... SBOOT2 section has been written successfully. Writing LOKE1ST section... LOKE1ST section has been written successfully. Writing LOKE2ND section... LOKE2ND section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing DTimPrimary section... DTimPrimary section has been written successfully. Writing DTimRecovery section... DTimRecovery section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing SSTD section... SSTD section has been written successfully. Writing NVM section... NVM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing PIT section... PIT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Selected firmware file: sm-j100f_xxu0aoa7_root.oct Please put the phone into Download Mode and connect USB cable. To put SM-J100F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Firmware writing successfully completed. unlocking process Platform: Samsung Android Selected port: COM13 Selected model: SM-J100F Detected phone model: SM-J100F Firmware compiled date: Sat Jan 17 20:56:26 KST 2015 PDA version: J100FXXU0AOA7 CSC version: J100FOJV0AOA7 SW version: J100FXXU0AOA9 Phone IMEI: 357554xxxxxxxxx Phone SN: R28G300924E Android version: 4.4.4 (KTU84P) Cheking Root Phone is Rooted Deactivating MSL... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NV-SM-J100F-35755xxxxxxxx file MSL deactivate successfully Unlocking phone... Please insert card into phone, if phone is locked, then type 00000000 Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------- put simcard enter 00000000 NO LUCK STILL LOCK put 12345678 NO LUCK STILL LOCK any idea to the team??? Last edited by Octopus box; 08-06-2015 at 08:43. |
08-05-2015, 10:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Please upload *.log and *.logx files of "Unlock" operation, from "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. Post here download link and we will check, where can be the problem. |
08-06-2015, 02:19 | #3 (permalink) | |
Member: 517175 Status: Offline Sonork: none Thanks Meter: 44 | Quote:
problem solve...this morning im preparing the log file and uploading but when i check the phone and re try to enter the 00000000 codes it succes... but yesterday after program root and unlock many times to restart but it can NOT accept the code... until the shop is close and off the unit for the night... then this morning try again to enter the code it accept and the unit is working... wierd but it works... | |
