05-27-2017, 22:44 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | sm-J106b connecting problem ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J106B Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J106B Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J106B Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J106B Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-J106B Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-J106B Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-J106B Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.5.4 Software version. |
05-29-2017, 07:32 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. To connect SM-J106B phone You need to enable "USB Debugging" option first. If problem will remain the same - try to re-install Samsung USB Drivers, try to use different USB ports of PC motherboard for connection. |
