Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 03-19-2017, 10:25   #1 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 263
SM-J120h 2016 FRP remove [Solved]
hi, i tried to remove frp on latest octopus 2.4.9 version,
i downloaded combination file on support : combination_olb_fa51_j120hxxu0apf1_olbfac_cl814769 3_qb9806767.oct
and then i flashed it, then clicked remove frp.
INFO : 3/19/2017 3:08:55 PM > To connect SM-J120H phone you have to perform the following steps:
INFO : 3/19/2017 3:08:55 PM > 1. Disconnect USB cable from phone.
INFO : 3/19/2017 3:08:55 PM > 2. Go to Menu->Settings->More->About Device.
INFO : 3/19/2017 3:08:55 PM > 3.Tap on "Build number" 7 times to enable developer options.
INFO : 3/19/2017 3:08:55 PM > 4. Go to Menu->Settings->More->Developer options.
INFO : 3/19/2017 3:08:55 PM > 5. Turn on "USB Debugging" option.
INFO : 3/19/2017 3:17:09 PM > Selected firmware file: combination_olb_fa51_j120hxxu0apf1_olbfac_cl814769 3_qb9806767.oct
WARN : 3/19/2017 3:17:13 PM > Please put the phone into Download Mode and connect USB cable.
WARN : 3/19/2017 3:17:13 PM > To put SM-J120H into Download Mode, You have to perform the following steps:
WARN : 3/19/2017 3:17:13 PM > 1. Reconnect the battery.
WARN : 3/19/2017 3:17:13 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys.
WARN : 3/19/2017 3:17:13 PM > 3. When phone turns on, press "Volume+" key.
INFO : 3/19/2017 3:17:13 PM > Found phone on
INFO : 3/19/2017 3:17:13 PM > Firmware write started.
INFO : 3/19/2017 3:17:13 PM > Writing BOOT section...
INFO : 3/19/2017 3:17:15 PM > BOOT section has been written successfully.
INFO : 3/19/2017 3:17:15 PM > Writing SBOOT section...
INFO : 3/19/2017 3:17:18 PM > SBOOT section has been written successfully.
INFO : 3/19/2017 3:17:18 PM > Writing SBOOT2 section...
INFO : 3/19/2017 3:17:20 PM > SBOOT2 section has been written successfully.
INFO : 3/19/2017 3:17:20 PM > Writing PARAM section...
INFO : 3/19/2017 3:17:22 PM > PARAM section has been written successfully.
INFO : 3/19/2017 3:17:22 PM > Writing KERNEL section...
INFO : 3/19/2017 3:17:25 PM > KERNEL section has been written successfully.
INFO : 3/19/2017 3:17:25 PM > Writing RECOVERY section...
INFO : 3/19/2017 3:17:28 PM > RECOVERY section has been written successfully.
INFO : 3/19/2017 3:17:28 PM > Writing SYSTEM section...
INFO : 3/19/2017 3:18:23 PM > SYSTEM section has been written successfully.
INFO : 3/19/2017 3:18:23 PM > Writing MODEM section...
INFO : 3/19/2017 3:18:26 PM > MODEM section has been written successfully.
INFO : 3/19/2017 3:18:26 PM > Writing WDSP section...
INFO : 3/19/2017 3:18:28 PM > WDSP section has been written successfully.
INFO : 3/19/2017 3:18:28 PM > Writing wfixnv2 section...
INFO : 3/19/2017 3:18:30 PM > wfixnv2 section has been written successfully.
INFO : 3/19/2017 3:18:30 PM > Writing CACHE section...
INFO : 3/19/2017 3:18:32 PM > CACHE section has been written successfully.
INFO : 3/19/2017 3:18:32 PM > Firmware writing successfully completed.
INFO : 3/19/2017 3:18:32 PM > Performed by 2.4.9 Software version.
INFO : 3/19/2017 3:19:05 PM >
INFO : 3/19/2017 3:19:06 PM > Platform: Samsung Android
INFO : 3/19/2017 3:19:06 PM > Selected port: COM66
INFO : 3/19/2017 3:19:06 PM > Selected model: SM-J120H
INFO : 3/19/2017 3:19:08 PM > Searching for a phone (waiting for ADB device)...
WARN : 3/19/2017 3:19:34 PM > Please, press "OK" button on the phone to allow USB debugging..
INFO : 3/19/2017 3:19:37 PM > Reading info...
INFO : 3/19/2017 3:19:40 PM > Detected phone model: SM-J120H
INFO : 3/19/2017 3:19:40 PM > Firmware compiled date: Wed Jun 1 11:06:46 KST 2016
INFO : 3/19/2017 3:19:40 PM > PDA version: FA51_J120HXXU0APF1
INFO : 3/19/2017 3:19:40 PM > CSC version: unknown
INFO : 3/19/2017 3:19:40 PM > SW version: J120HXXU0APD1
INFO : 3/19/2017 3:19:40 PM > Phone SN: R51H61CZS8J
INFO : 3/19/2017 3:19:40 PM > Android version: 5.1.1 (LMY47V)
INFO : 3/19/2017 3:19:40 PM > Sales code: unknown
INFO : 3/19/2017 3:19:40 PM > Country: unknown
INFO : 3/19/2017 3:19:40 PM > HW platform: sc8830
INFO : 3/19/2017 3:19:40 PM > HW Chip: SC7727SE
INFO : 3/19/2017 3:19:40 PM > HW Modem: SC7727SE
INFO : 3/19/2017 3:19:40 PM > Security patch level: 2015-12-01
INFO : 3/19/2017 3:19:40 PM > Codename: j1x3gxx
INFO : 3/19/2017 3:19:40 PM > Resetting FRP lock..
WARN : 3/19/2017 3:20:11 PM > FRP lock is successfully reseted!
BINF : 3/19/2017 3:20:11 PM > Goto "Menu->Settings->Backup and reset" and make "Factory data reset"
INFO : 3/19/2017 3:20:13 PM > Performed by 2.4.9 Software version.
but the problem is, frp is still ON and when i flash stock firmware, 4 files or single pda file, the phone is stuck on samsung logo or ramdump normal mode
no recovery menu.
i tried to flash other files but still the same. i can only get to menu on flashing combi file but it is on the combination file system menu only.
i have tried flashing new firmware, have tried other method like select j120f or j500h and remove frp but frp is still on.
any suggestions?
Old 03-19-2017, 10:39   #2 (permalink)
engcobocell's Avatar
Member: 2590583
Thanks Meter: 198
Check these is j120 frp
https://m.youtube.com/watch?v=bUWT8CMmDMY
Sent from my SM-A300FU using Tapatalk
Old 03-19-2017, 10:40   #3 (permalink)
Member: 2590583
Thanks Meter: 198
how to remove frp from all samsung phone without any software 03/11/2017
Old 03-19-2017, 10:41   #4 (permalink)
Member: 2590583
Thanks Meter: 198
Search is Google these u well get what u want
Old 03-20-2017, 09:24   #5 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
Hello.
If You wrote full Combination firmware, there's no need to make "Reset FRP". Here are two methods, of how to reset FPR using Combination firmware (to enable ADB):
I.
  1. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check all partitions except "boot.img").
  2. Perform "Reset FRP" operation in Software.
II.
  1. Write Full Combination Firmware.
  2. Go to "Developer Options" in phone Settings.
  3. Check "Enable OEM unlock" option.
  4. Make Factory Data Reset.
  5. Reflash the phone with full stock (orignal) firmware.
Note: "boot.img" of Combination firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares).
You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk!
If neither of these methods helps, necessary files are missing, or You don't want to take risk - You can use Factory Reset FRP Service.
The Following 3 Users Say Thank You to Octopus box For This Useful Post:
Old 03-27-2017, 14:43   #6 (permalink)
Member: 2379435
Thanks Meter: 5
I tried it but when i try to write the combination firmware, being the full file, or only boot file, it asks for a PIT file.
"Please select firmware with PIT"
I wrote a full post but Forum said i cannot post it untill i have 10 posts.
So i hope you can help me with this mini information i could drop.
I'm using 2.4.9 version.
Old 03-27-2017, 15:25   #7 (permalink)
Member: 2379435
Thanks Meter: 5
I tried the operation selection SM-J120FN, Reset FRP, and the device is a J120H
But surprisingly it worked!
Didn't needed to flash any file.
Check Log.
Plataforma: Samsung Android
Porto seleccionado: COM1
Modelo seleccionado: SM-J120FN
Reset FRP/ Reactivation lock operation for SM-J120FN will delete all user data on the phone (contacts, pictures and others)!
NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service.
Connecting to server...
Connecting to server...Ok!
Checking resource files...
Resource files already downloaded.
To put SM-J120FN into Download Mode, You have to perform the following steps:
Waiting for phone...
Escrevendo a secção Custom...
A secção Custom foi escrita com êxito
Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset"
The Following 3 Users Say Thank You to TJChagas For This Useful Post:
Page generated in 0.20935 seconds with 8 queries
